My twinturbo build - Page 7
Page 7 of 9 FirstFirst ... 456789 LastLast
Results 61 to 70 of 84
Thread: My twinturbo build
  1. #61
    Senior Member Napstar's Avatar
    Sep 2017
    Sweden
    Quote Originally Posted by CFI View Post
    No one drains into a tank. These cars have a factory scavenge system, utilize it.
    How about this solution??
    Oct 2014
    ny
    Small update finished front cooler with 2 -12 an fittings for inlet outlet and -10 for drain now will get powder coated
    Finished the air to water cooler added tial bovs and 2 maf adapters just need to make tabs to hold it to the brace underneath and need to clean the core from any dust / aluminum pieces if anyone has any good suggestions ? Hot tank maybe?
    Attached Thumbnails Attached Thumbnails My twinturbo build-6e0a413c-1efb-42f3-b654-7f8be4070929_1567892221813.jpg   My twinturbo build-5b702ca4-a963-4fe9-9979-6136aa0664b7_1567892240020.jpg   My twinturbo build-7a360ab1-adeb-4f07-8bc0-10f9b3300228_1567892259519.jpg
  4. #63
    CFI
    CFI is offline
    Oct 2017
    LA
    Re: My twinturbo build
    Quote Originally Posted by TheCzarofMexico View Post
    I would imagine you could do that. The pump should be able to pump through what little oil is in the pan (dry sump). But a gravity drain alone won't do that alone, even with the reservoir you made.
    doesn't need a scavenge pump when you have a factory dry sump system scavenging oil from the pan you drain into.
    Sep 2017
    Sweden
    Is it possible to drain it in the oilplugg thrue a banjo?
  7. #65
    CFI
    CFI is offline
    Oct 2017
    LA
    Quote Originally Posted by Napstar View Post
    v10-questionable
    v8- no , drain plug is just to small.
  8. #66
    Oct 2014
    ny
    Small update got some parts back from powder coating finally starting to look nice
    Attached Thumbnails Attached Thumbnails My twinturbo build-c2d86df6-fbb4-4524-bfd6-8fa0e0c9eea6_1568239226389.jpg   My twinturbo build-62468c6a-19a1-44ae-98cf-63ff5518367c_1568239243850.jpg   My twinturbo build-c87af681-2f74-4021-8383-573b1c8a88e4_1568239263296.jpeg   My twinturbo build-c3a98835-3b73-4244-b133-21d03a60365e_1568239272208.jpg
  9. #67
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Looking good.
  10. #68
    Senior Member NTM09's Avatar
    Mar 2019
    Michigan
    looks good, cant wait to see the final product and numbers.
    and when you're going to build mine
  11. #69
    Oct 2014
    ny
    Small update fitted the cooler bracket and the cooler now need to finish oiling and will be staring
    Attached Thumbnails Attached Thumbnails My twinturbo build-12d28777-4796-46e5-8ba9-4fe4864ac537_1568302323403.jpg   My twinturbo build-9414c17b-edb0-4b8e-8b4e-f41f846bcb91_1568302335220.jpg   My twinturbo build-6fde7149-51b9-4e35-bba6-ff16e43f979b_1568302377975.jpg
  12. #70
    Oct 2014
    ny
    Wastegates on turbo housing powder coated doing a shorty exhaust for now and will ceramic coat exhaust housings / exhaust
    Attached Thumbnails Attached Thumbnails My twinturbo build-747fa420-22a5-4079-9848-ffb3fa6c0471_1568682872059.jpg   My twinturbo build-47060700-f5bc-4fc4-82b2-77253d5456cc_1568682885897.jpg   My twinturbo build-9ab32346-40e4-48b4-bfff-a65924bac16c_1568683007944.jpg
