My twinturbo build
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: My twinturbo build
    Oct 2014
    ny
    My twinturbo build
    I will be documenting my twinturbo build and would like to thank Napstar for alot of helpfull information as of now i still have some unanswered questions
    any help is appreciated i still cannot figure out the crankcase vent would not want to pressurize the engine
    also not sure what pump to use after the turbos drain into the drain catch can
    Build details
    pte 6266 x 2 v band in and out
    tial 44mm wastegates
    tial bov
    custom air to water setup with ice tank in the frunk
    My twinturbo build-img_8773.jpgMy twinturbo build-img_8772.jpgMy twinturbo build-img_8771.jpg
    Jan 2019
    Re: My twinturbo build
    Can't wait to see the results. Why didn't you use the upper mounts instead of the lower rubber mounts for you kit? I usually see them hung up there. Have you mocked the space for intake and exhaust lines to the turbo? Looks like you're a little on the narrow side most of the turbos I've seen are a few more inches over above the two aluminum supports for the bumper. If you look at the posts from steepey race or underground racing they have the turbos angled as well. Just curious to know if you're moving forward with the current setup.
    Oct 2014
    ny
    hey thanks the bar on top holds the turbos but because of the weight its hard to position them so i added lower mounts to hold them in place for now
    and as far as the turbos being out more then its very difficult to run the charge pipes i think it will be ok
    Jan 2019
    looking forward to seeing the progress. I looked hard between the turbo and supercharger setup. In the end just for simplicity and fun I went with vf. What are you doing for ecu? Are you doing it yourself or having a shop do it?
    Oct 2014
    ny
    always wanted to turbo the car supercharger is a great alternative
    tunning will be done by a local tuner
    so for oil feed i am not sure where to get it napster suggested under the oil filter housing but i am not sure i have an emply plug there on the v10
  8. #6
    Supporting Vendor VividRacing's Avatar
    Jun 2019
    Gilbert, AZ
    I cannot wait to see how this unfolds. Following!
    Ryan 'Michael'
    Audi Performance Specialist
    Vivid Racing | Gilbert, AZ | Hidden Content
    480.966.3040 x270 | Email: Hidden Content
    KW | Vorsteiner | Brembo | BBS Wheels | Airlift | Bilstein | Armytrix | Tubi Style | Liberty Walk |Quicksilver | H&R | 1016
  9. #7
    Jan 2019
    Quote Originally Posted by lex99frc View Post
    When I was looking at going turbo I had found that it was tapped into the oil drain bolt. Not sure if that's correct but I believe I remember seeing it on a youtube video. Not sure if you've heard of Tavarish but he restored a twin turbo Gallardo on his channel that had caught on fire.
  10. #8
    Jan 2019
    personally I'd use something like this to feed the oil lines. Not sure if I like the sound of tapping in at the drain plug.
    https://www.ebay.com/itm/Blue-M10x1-...-/390614396555
    Someone else can comment on the size
  11. #9
    Jul 2019
    SoCal (Oak Hills)
    For the crank case breather, you can just vent it to atmosphere, or you can add a one way check valve so it only works under vacuum and not boost. For the oil drain, you can take the oil tank out and have someone weld a bung in it and have it drain there. Same with feeding them, you can add a bung at the bottom of the tank or t-into a feed line. Plenty of options, just have to think outside to box. If you want to use one of the drain bolts, find a banjo bolt to replace it so you don't need to modify anything, then you can just use a banjo fitting to an AN fitting.
    2012 F350 Diesel CC LB DRW Lariat FX4 with A/C seats
    1991 Toyota Pickup CARB legal 3.4 TRD supercharged swap desert adventure truck
    1999 Toyota 4Runner Limited AWD with custom Turbo setup
    2008 Mazdaspeed3 GT Stock daily
    Future car - V10 Gated Coupe or 50x60 steel building
  12. #10
    Jun 2019
    Awesome project, planning on doing this too one day!
    How about picking oil from the cylinder head, might be an option somewhere.
    How are you going to remove the cats, engine out? It's stated that some large companies just knock out the internals without removing the engine. I guess this could be done if you pressurize the cylinder with open exhaust valves.
