R8 RWD conversion 2016-
Results 1 to 7 of 7
Thread: R8 RWD conversion 2016-
    Aug 2019
    Hi guys!
    I know it's possible to do RWD conversions on the previous generation R8 and Gallardos. But how is it with the new ones? Is it possible to do it as easy as before or are you going to have problems with the electronics or stuff like that?
    Have anyone done it?
    Have been searching online for a while without any luck.
    Would like to have a RWD R8 but the market with good spec R8 RWS over here in Europe are not so good ATM, especially not in Sweden.
    Best regards,
    Alexander
    Supporting Vendor ULTIMATEPD's Avatar
    Oct 2014
    Houston, TX
    Re: R8 RWD conversion 2016-
    We can supply you with the hardware, that is the easy part.
    You will need someone to code the electronics to RWD.
    VAG COM Service in Houston - PM me
    OEM Clutch kits, Pedalbox, TCU tunes, Exhaust systems, OEM Genuine Parts
    Carbon Fiber accessories.
    Hidden Content
    Hidden Content Hidden Content
    IG shardul_amg
    Hidden Content
    Aug 2019
    Quote Originally Posted by ULTIMATEPD View Post
    Okey! What systems will need to be coded? Can a ”regular” tuner manage this?
    The only physical work that’s needed are to take out the driveshaft, diff and front axles and install the new hardware right?
    Oct 2014
    Houston, TX
    You will need access to Odis or Vagcom to code the car
    Yes to your second question, We can make you a set of hubs take be about a week.
    Hidden Content
    IG shardul_amg
    Hidden Content
    Aug 2019
    Okey thanks!
    What’s the price of the hubs and how much for shipping to Stockholm, Sweden?
  8. #6
    Oct 2014
    Houston, TX
    PM sent........
    Hidden Content
    IG shardul_amg
    Hidden Content
  9. #7
    Aug 2019
    Bump!
    So what I understand the differential is electronic in the gen 2 and it can send up to 100% of the power to the rear. Does anyone know if it’s possible to make it rwd with just coding?
  10. Remove Advertisements
