R-tronic: replacing clutch position sensor G476
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: R-tronic: replacing clutch position sensor G476
    Dec 2017
    philadelphia
    removed airbox etc...
    i can see the sensor and the hole it goes into the tranny is there no way to replace this guy without pulling off the whole tranny?
    seems kinda crazy that it would be the same amount of work as a clutch change.
    thanks
    photo:
    https://www.dropbox.com/s/hpxdf9w9sc...07378.jpg?dl=0
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: R-tronic: replacing clutch position sensor G476
    You have to split the transmission from the engine, the sensor (G476) is mounted on a bracket (1 bolt) which is located by 2 dowel pins. A special tool is recommended for removing the sensor bracket T10055. The sensor is $210 U.K. price. My suggestion if your mileage is high enough, is change the clutch at the same time, if R-Tronic, change the clutch release bearing as well. Overall an expensive job!
    Dec 2017
    philadelphia
    were in the process now of taking the transmission out now, will check out the clutch and release bearing while we are at it...
    thanks for your replies.
    Mar 2015
    thanks for your replies.[/QUOTE]
    You´re welcome and good luck.
    Mar 2015
  8. #6
    Dec 2017
    philadelphia
    some photos of the process, just finished taking out the oil canister
    some interesting things i found out/notes .
    -you can see the clutch through the trans to check the clutch life on an R-tronic (read somewhere thats only on a manual)
    R-tronic: replacing clutch position sensor G476-dsc07275.jpg
    R-tronic: replacing clutch position sensor G476-dsc07289.jpgR-tronic: replacing clutch position sensor G476-dsc07390.jpgR-tronic: replacing clutch position sensor G476-dsc07382.jpgR-tronic: replacing clutch position sensor G476-dsc07412.jpg
    will get better more docu-type photos off the process.
  9. #7
    Mar 2015
    jigsaw puzzle for adults eh!
  10. #8
    Dec 2017
    philadelphia
    one millionnnn pieces lol
  11. #9
    Mar 2015
    Make sure nobody throws in an extra piece, you´ll spend the rest of your time with the car wondering where it came from when it´s left over at the end of the job kkkkkk.
  12. #10
    Senior Member CraigFulton's Avatar
    Jun 2017
    Clearwater, FL
    Hell yeah man! Love to see others getting in there and fixing it themselves. Any pics of where the inspection hole is to see the clutch?
  1. Fault Code PO366 (Camshaft Position Sensor)
    By axt3 in forum Maintenance and Service
    Last Post: 10-26-2018, 04:19 PM
  2. Replies: 0
    Last Post: 02-11-2018, 11:04 PM
  3. Replacing the clutch on an R-tronic R8?
    By SebringSilver in forum Maintenance and Service
    Last Post: 06-21-2015, 10:26 AM
  4. FS: Audi R8 V10 R-Tronic Original NEW Clutch (Clutch plates and pressure plate)
    By LD-OEM Parts in forum Vendor Classifieds and Specials
    Last Post: 07-26-2014, 08:08 AM
  5. Clutch Temperature Sensor on 4.2I R-Tronic
    By markuso in forum Performance Modifications
    Last Post: 07-07-2011, 05:03 AM
