1 - 1 of 1 Posts
http://www.popularmechanics.com/blogs/automotive_news/4303504.html
Some nice pic on the link above:
MARBELLA, Spain—Audi's R8 didn't need much to join the top-tier supercar ranks. The two-seat road rocket nearly had it all—a lightweight aluminum structure and body, midengine layout, all-wheel drive and a design that left bystanders, well, lusting for another look. The missing piece has just been added—a 518-hp version of the V10 from the Lamborghini Gallardo LP560-4.
The original Audi R8 and its 420-hp V8 will still be offered, but later this year, the V10 model arrives stateside. Expect the price to balloon from $115,250 to around $190,000. That's certainly a lot of dough—especially in this economy. But as we learned, driving the car on mountain roads and the Ascari race track in southern Spain, it's one of the few cars that just might be worth the price of a house. —Larry Webster
The Specs
The 5.2-liter Lambo V10 makes slightly less horsepower (518 versus 552) in the R8 because of revised engine mapping and exhaust tuning.
The aluminum motor resembles a race engine. It spins to a hair-raising 8700 rpm, resulting in a frighteningly fast 88.3-ft-per-second maximum piston speed. To retain crankshaft rigidity without increasing weight, the crank uses common-pin journals that, combined with the 90-degree bank angle, mean an uneven firing interval of 54 and 90 degrees. It makes for a delectable exhaust screech.
The double-overhead camshafts feature variable valve timing. A dry-sump oiling system reduced engine height to 27.4 in., which allowed the engineers to mount the engine lower in the chassis for a more advantageous center of gravity. The cooling effects of the direct fuel injection permitted a lofty 12.5:1 compression ratio. Careful attention to the overall mass leaves the V10 at 569 pounds, a mere 68 pounds over the V8. The driveline remains the same as the 4.2-liter R8. Buyers can choose between a six-speed manual or a six-speed automated manual called R tronic. Both use a small-diameter twin-plate clutch. The all-wheel-drive system has a viscous center coupling that can send a maximum of 35 percent of engine power to the front wheels. A mechanical limited-slip diff powers the rear. And as before, the R8 is available with the adjustable magnetic-rheological shocks that come on the Corvette ZR1.
The V10's compact dimensions—it's only 25.4 in. long—means the new engine fits in the R8's engine bay without significant modification. So the passenger compartment retains the rear luggage shelf and plenty of legroom. A front trunk provides additional storage. In fact, the V10 model is as user-friendly as ever. But as we found out, it now comes with a serious kick.
The Drive
The V8 R8 is decidedly quick—0 to 60 mph in 4.74 seconds and a quarter-mile time of 12.93 at 109.4 mph. The V10 version, however, simply blows it away. With our VBOX GPS test gear, we clocked the V10 to 60 mph in only 3.81 seconds. It cleared 100 mph in 8.41 seconds, passed the quarter-mile mark in 11.80 at 119.5 mph, and effortlessly blew past 150 mph in 19.81 seconds. Those are serious times, just a few ticks off the monster 638-hp Corvette ZR1.
And yet, achieving these times in this car couldn't be easier. We tested the R tronic model with its handy launch-control feature. To engage, first turn off the stability control, select the sport mode (it shifts quicker) and simultaneously press the gas and brake. The computer automatically dials up about 5000 rpm. Releasing the brake results in a perfectly automated clutch dump—and you're gone. Upshifts pin you in the seat as the car gallops forward, inhaling ever longer stretches of pavement as the engine howls aggressively. We could do this all day.
Luckily, the R8 is exceedingly stable. If we had the room, we're sure we could have comfortably run up to the 196-mph top speed. Those adjustable shocks work wonders. The body remains nearly flat at all times on even the tightest corners, and bumps are smoothed easily.
It's certainly a firm-riding car, but the payoff is a Ginsu-like handling precision. The R8 carves through bends with total confidence and doesn't feel nearly as intimidating as those 518 ponies suggest it might. In other high-powered exotics, there's always this unnerving suggestion that a mistake, no matter how slight, could result in catastrophe. Not here. The R8 just digs in and gets the job done, a testament to the stiff aluminum structure, perfectly weighted steering—and many long hours clocked by the Audi engineers.
Amazingly, the R8 is rewarding even if you're not driving flat out. On some curvy mountain roads, where an off-course excursion would mean a likely fatal drop, we, of course, dialed it back in the name of self preservation. The car felt eager and agile despite the reduced speed. The R tronic transmission is a delight in the hills, snapping upshifts and blipping the throttle for downshifts. Plus, the all-wheel-drive system allows ham-footed throttle applications without fear of losing the back end. If we had to find a fault—and we're searching here—it's that the handling isn't as balanced as we'd like. The car tends to scrub the front tires. And as good as the automated manual is during spirited driving, there are still annoying shift lags when driving in town. A double-clutch gearbox is sorely needed. Or—you could just order the manual transmission.
The Bottom Line
Perhaps the best part of the V10 R8 is the fact that the car has lost none of its civility in its high-horsepower transformation. There's still ample cargo room; the visibility up front is expansive, the air conditioning works like any other Audi's, and it's as comfortable as it is fast. The R8 is still the exotic that you could let your grandma drive. Only now, it's one of the quickest cars on the road.
Test Results
Base price $190,000 (est)
Powertrain 518 hp/391 lb.-ft. 5.2-liter V10, 6M
Suspension (f/r) control arms/multilink
Wheelbase (in.) 104.3
Length (in.) 174.6
Width (in.) 76
Axle ratio 3.08
Brakes (f/r) 14.4-in. disc/14.0-in. disc, ABS, ESC
Tires (f/r) 235/35ZR19 (91Y) 305/30ZR19 (102Y)
0-30 mph 1.6
0-60 mph 3.81
0-100 mph 8.41
0-150 mph 19.81
Quarter-mile 11.80 @119.50 mph
30-0 mph 26.55
60-0 mph 103.11
EPA fuel economy (city/hwy) 11/18 (est)
1 - 1 of 1 Posts
