1 - 20 of 25 Posts
After going head to head with a buddy’s 2020 car on a few pulls with my 18 V 10 plus it was quite clear, chime in guys....
I did recently do a lot of data collection to put together an interesting side-by-side of Gen2 R8's as well as Huracans:
2016-2018
R8 V10
2016-2018
R8 V10
PLUS
2019/2020
R8 V10
2019/2020
R8 V10
Performance
2014-2018
Huracan
LP610-4
2017
Huracan
Performante
2019/2020
Huracan
Evo
Power548 PS
540 HP
610 PS
601 HP
570 PS
562 HP
610 PS
601 HP
610 PS
601 HP
640 PS
631 HP
640 PS
631 HP
Curb
Weight
lbs
3616348336603516341333253413
Curb
Weight
kgs
1640158016601595154815081548
DRY
Weight
lbs
3278320533223238313530473135
DRY
Weight
kgs
1487145415061469142213821422
Weight
Factors
21.9 Gal
Fuel Tank
19.3 Gal
Fuel Tank
Carbon
Ceramic
Brakes
Reduced
Sound
Deadening
and
Carpet
Linings
Weight
Increase
Over 2016
Model Due
To Additional
Emissions
Components
Weight
Increase
Over 2016
Model Due
To Additional
Emissions
Components
1st3.1333.1333.1333.1333.1333.1333.133
2nd2.5882.5882.5882.5882.0832.0832.083
3rd1.8801.9581.8801.8801.5751.5751.575
4th1.244
1.140
1.2441.2441.2441.2441.244
5th0.9790.8980.9790.9790.9790.9790.979
6th0.9760.8840.9760.9760.7880.7880.788
7th0.8410.6530.8410.8410.6770.6770.677
60-100
kmh
4th Gear
3.62.63.43.22.52.32.4
80-120
kmh
4th Gear
3.52.63.43.12.52.32.3
80-120
kmh
5th Gear
4.83.54.64.33.433.1
80-120
kmh
6th Gear
6.84.76.564.54.14.2
60-100
kmh
1.71.51.61.41.41.31.4
80-120
kmh
21.81.91.81.81.61.7
100-180
kmh
65.25.75.254.74.8
40-60
MPH
4th Gear
32.12.82.621.82
50-70
MPH
4th Gear
2.92.12.72.521.81.9
50-70
MPH
5th Gear
42.83.73.52.72.52.6
50-70
MPH
6th Gear
5.73.85.34.93.63.33.5
40-70
MPH
2.22
2
1.9
2
1.9
2
50-90
MPH
3.73.13.43.23.23
3.1
Discussion Starter #7
2016-2018
R8 V10
2016-2018
R8 V10
PLUS
2019/2020
R8 V10
2019/2020
R8 V10
Performance
2014-2018
Huracan
LP610-4
2017
Huracan
Performante
2019/2020
Huracan
Evo
Power548 PS
540 HP
610 PS
601 HP
570 PS
562 HP
610 PS
601 HP
610 PS
601 HP
640 PS
631 HP
610 PS
601 HP
Curb
Weight
lbs
Curb
Weight
kgs
DRY
Weight
lbs
DRY
Weight
kgs
Weight
Factors
21.9 Gal
Fuel Tank
19.3 Gal
Fuel Tank
Carbon
Ceramic
Brakes
Reduced
Sound
Deadening
and
Carpet
Linings
Weight
Increase
Over 2016
Model Due
To Additional
Emissions
Components
Weight
Increase
Over 2016
Model Due
To Additional
Emissions
Components
3rd1.8801.9581.8801.9581.5751.5751.575
4th1.244
1.140
1.2441.1401.2441.2441.244
5th0.9790.8980.9790.8980.9790.9790.979
6th0.9760.8840.9760.8840.7880.7880.788
7th0.8410.6530.8410.6530.6770.6770.677
60-100
kmh
4th Gear
80-120
kmh
4th Gear
80-120
kmh
5th Gear
4.83.54.64.33.433.1
80-120
kmh
6th Gear
6.84.76.564.54.14.2
60-100
kmh
80-120
kmh
21.81.91.81.81.61.7
100-180
kmh
65.25.75.254.74.8
40-60
MPH
4th Gear
32.12.82.621.82
50-70
MPH
4th Gear
2.92.12.72.521.81.9
50-70
MPH
5th Gear
42.83.73.52.72.52.6
50-70
MPH
6th Gear
40-70
MPH
2.22
2
1.9
2
1.9
2
50-90
MPH
3.73.13.43.23.23
3.1
Just as I thought !
I could be wrong, but I am almost certain that the gearbox and ratios for the 2020 R8 is identical between the base and the performance. Don’t believe there are 2 different transmissions anymore.
I think you're right, as it would explain why the times are so close between Base R8 and Performance R8.
Ratios are corrected now.
It does also seem to depend on what sources the information is culled from, as I found varying numbers among a couple different online sources, but unfortunately have not found any official documentation from Audi.
Discussion Starter #11
True the base
true the base car and the 2020 are much closer in performance spec numbers 😉
Interesting I wonder why the 2020 performances didnt get the 2017/2018 Plus shorter gear ratios, if you believe all the keyboard race car drivers on here the shorter ratios are vastly superior ;)
So the numbers tell the tale...
There are 3 variables at play between the Plus and the Performance are: Weight, Power, and Gearing.
But the amount of weight each unit of power must carry is so close between the Plus and the Performance, that it's mostly a wash:
2016-2018
R8 PLUS
2019-2020
R8 Performance
kgs per PS
2.590​
2.573​
lbs per HP
5.795​
5.755​
Which makes it reasonable to suggest that gearing does truly play a large role.
We can see the short gearing dominance in 4th, 5th, and 6th gears:
2016-2018 R8
V10 PLUS
610 PS / 601 HP
1580 kgs / 3483 lbs
2019-2020 R8
V10 Performance
620 PS / 611 HP
1595 kgs / 3516 lbs
1st Gear / Top Speed kmh3.133 / 743.133 / 79
2nd Gear / Top Speed kmh2.588 / 1122.588 / 119
3rd Gear / Top Speed kmh1.958 / 1471.880 / 164
4th Gear / Top Speed kmh1.140 / 1871.244 / 217
5th Gear / Top Speed kmh0.898 / 2370.979 / 276
6th Gear / Top Speed kmh0.884 / 2960.976 / 348
7th Gear / Top Speed kmh0.653 / 3430.841 / 472
60-100 kmh 4th Gear2.63.2
80-120 kmh 4th Gear2.63.1
80-120 kmh 5th Gear3.54.3
80-120 kmh 6th Gear4.76
2016-2018 R8
V10 PLUS
610 PS / 601 HP
1580 kgs / 3483 lbs
2019/2020 R8
V10 Performance
620 PS / 611 HP
1595 kgs / 3516 lbs
1st Gear / Top Speed MPH3.133 / 463.133 / 49
2nd Gear / Top Speed MPH2.588 / 702.588 / 74
3rd Gear / Top Speed MPH1.958 / 911.880 / 102
4th Gear / Top Speed MPH1.140 / 1161.244 / 135
5th Gear / Top Speed MPH0.898 / 1470.979 / 172
6th Gear / Top Speed MPH0.884 / 1840.976 / 216
7th Gear / Top Speed MPH0.653 / 2130.841 / 293
40-60 MPH 4th Gear2.12.6
50-70 MPH 4th Gear2.12.5
50-70 MPH 5th Gear2.83.5
50-70 MPH 6th Gear3.84.9
Two things I noticed:
  1. Although the base R8 has the advantage from 1 to 3 - as it's 3rd gear is shorter - when both are non-tuned the Plus' higher power and lower weight bring it ahead.
  2. On the 1/4 mile runs for Gen2 R8's, we've seen them land in the 120's, which from the gearing means that the Plus - tuned or not - will have to shift through to 5th by the end.
Elsewhere on the forum, we've seen that a Tuned R8 base will outperform a non-tuned PLUS.
This is supported by fact that the power bump means less weight has to be hauled around, giving the additional power the opportunity to take advnatage of the lower 3rd gear, and that for the 1/4 mile the base R8 would have one less gear shift.
But once we start comparing Tuned-to-Tuned, the Plus is back on top with the least amount of weight per unit of power.
2016-2018
R8 V10
Tuned
2016-2018
R8 V10
2016-2018
R8 V10
PLUS
Tuned
2016-2018
R8 V10
PLUS
2019/2020
R8 V10
Tuned
2019/2020
R8 V10
2019/2020
R8 V10
Performance
Tuned
2019/2020
R8 V10
Performance
Power PS548640610640570640610640
Power HP540631601631562631601631
Curb Weight kgs16401640158015801660166015951595
Curb Weight lbs36163616348334833660366035163516
kgs per PS2.992.562.592.472.912.592.612.49
lbs per HP6.705.735.805.526.515.805.855.57
Interesting thread guys and a lot of work from Thedragonseven.
I believe you have the ratios for the 2016 v10 / v10 plus the wrong way around. The lower the ratio the higher the gear so the 0.653 7th belongs to the base v10. Both models have the same first and second gear ratios, but the base model is higher in every other gear. If the 2020 ratios are as you quote then that would mean both models have the shorter ratios from the 2016 v10 plus.
To see the fuller picture of how the ratios are spaced out you would have to multiply by the final drive ratio for the respective gear. This relates to the compact design of the R8 gear box which has two lay shafts, each with a different final dive ratio, rather than a single output shaft like some of the other Stronic gearboxes. I believe its similar to the early VW DSG box in the Golf. Thats why you see 5th and 6th gear almost the same ratio as they are driving through different lay shafts.
The final drive ratios are :
4.458 for reverse, 1st, 4th + 5th
3.588 for 2nd, 3rd, 6th, + 7th
Discussion Starter #15
2016-2018
R8 PLUS
2019-2020
R8 Performance
kgs per PS
2.590​
2.573​
lbs per HP
5.795​
5.755​
2016-2018 R8
V10 PLUS
610 PS / 601 HP
1580 kgs / 3483 lbs
2019-2020 R8
V10 Performance
620 PS / 611 HP
1595 kgs / 3516 lbs
2016-2018 R8
V10 PLUS
610 PS / 601 HP
1580 kgs / 3483 lbs
2019/2020 R8
V10 Performance
620 PS / 611 HP
1595 kgs / 3516 lbs
2016-2018
R8 V10
Tuned
2016-2018
R8 V10
2016-2018
R8 V10
PLUS
Tuned
2016-2018
R8 V10
PLUS
2019/2020
R8 V10
Tuned
2019/2020
R8 V10
2019/2020
R8 V10
Performance
Tuned
2019/2020
R8 V10
Performance
You know the base car guys along with the facelift guys hate to hear this 🙉
From Audi, about the Plus:
Seven speed S tronic dual-clutch transmission
The new transmission not only focuses on high levels of performance and acceleration but also emphasizes efficiency. On V10 models, the gear ratio configuration is referred to as 6+overdrive, with the top track speed being reached in the 6th gear. V10 plus models feature a gear set uniquely suited for high-performance oriented driving with no overdrive gears. In this set up, gears 3 through 7 feature shorter ratios that provide a closer shift pattern, allowing the V10 FSI® engine to remain at a higher RPM to allow for increased performance. In this configuration, the top track speed is reached in 7th gear.
I can't find the actual specs in any Audi media thus far, but did have them at one time.
I'll post them if I can find them again.
Still cannot find any official Audi docs, but here's how unreliable the magazine sources are:
Car & Driver
2017 R8
Car & Driver
2017 R8 Plus
iSeeCars
2017 R8
iSeeCars
2017 R8 Plus
Automobile
Catalog
2017 R8
Automobile
Catalog
2017 R8 Plus
1st Gear-
3.13​
3.13​
3.13​
3.13​
3.13​
3.13​
2nd Gear-
2.59​
2.59​
2.59​
2.59​
2.08​
2.08​
3rd Gear-
1.96​
1.88​
1.96​
1.88​
1.51​
1.58​
4th Gear-
1.24​
1.14​
1.24​
1.14​
1.14​
1.24​
5th Gear-
0.98​
0.90​
0.98​
0.90​
0.90​
0.98​
6th Gear-
0.98​
0.88​
0.98​
0.88​
0.71​
0.79​
7th Gear-
0.84​
0.65​
0.84​
0.65​
0.53​
0.68​
Nice find.
So although the gear ratio numbers I found and posted were switched, you did confirm that the 2020 models no longer differentiate with shorter gears.
But that doesn’t change the measured times it took, and the Plus gearing still benefits from the short gearing in 4th, 5th, and 6th gears.
The weight-per-unit-of-power also remains valid, with the Plus having the advantage.
And even with the weight savings of the RWS, it remains heavier than the Plus.
1 - 20 of 25 Posts
