1 - 5 of 5 Posts
Is the bore and stroke for the new V10 and the V8 the same ?? Is the compression ratio the same ? This way same parts ( pistons, con.rods, bearings, etc.) can be used in both engines? This question aimed at the new member who works at Audi.
I don't know enough to answer your question but you should send the person its aimed at a PM just incase they don't read this ;)
AFAIK, both V8 and V10 are 84.5mm X 92.8mm bore and stroke, 12.5:1 compression
I have read that the engines have the same bore (3.33", 84.5mm), stroke (3.65", 92.8mm), compression ratio (12.5:1). If you use the Audi website and look at specifications, it is all listed there.
Discussion Starter · #5 ·
Just as I imagined . :)
1 - 5 of 5 Posts
