1 - 11 of 11 Posts
254495
254496
i am trying to avoid shimming the car. my goal is to get some better turn in and acceleration. thanks.
I know nothing about shimming the camber but gratuitous photos of attractive ladies will ALWAYS get my attention, thanks for posting.
You probably will struggle to get more than about -1.5 degrees camber which possibly won't be enough for track use. My car only goes on track once or twice a year so the settings are a compromise, but are here;
Front - camber -1.5, toe parallel.
Rear - camber -1.2, toe + 0.5
Discussion Starter #5
great. thanks. that is a start. will prob just stick sport cup 2s on. that will probably make more of an impact that anything else.
I track a fair bit but also daily the car so just maxed out the front without adding shims. The Cup 2’s like a lot of negative camber and low pressures. I wear the outer shoulders quickly because I can’t get the camber they need, which is a minimum of -2.5 to help with wear. The better solution is Toyo R888R. They do well with normal camber and last much long than the Cup 2’s.
Discussion Starter #7
what did you max the front camber at? any toe changes? what about the rear camber?
with the 4S i start at 27 pre stint and they heat to 33-35 and do well.
I was looking at the Toyos, wanted to try them, but I know the load rating is lower than the Trofeos I use. Also saw some comments on not using them on an R8 unless it is lightened. How has your experience been with them? I'm using 325 x 19 on the rear and the Toyos load rating is the same, but the front I am using 245 x 19 and it is less than the Trofeo and that is my concern. I have felt my fronts feel like they are rolling in the corners if my pressure is too low. That scared me away from the Toyos.
Er, I don't recall anyone asking me for permission to use pics of my current better half in their post! :oops::p
2017 R8 Plus Coupe 2014 SQ5
Here’s my track alignment specialist. She really good but a bit expensive.
Sensitive content, not recommended for those under 18 Show Content
260688
I digress.
260692
Reactions: DaveL
1 - 11 of 11 Posts
