1 - 9 of 9 Posts
For any of you out there with the Carista software [iPhone or Android], here is what is available in the Beta version for the Gen2 R8's...
Doors / Windows / Remote
Auto-lock doors when moving
  • *YES* / NO
Auto-unlock doors when key is taken out of ignition
  • *YES* / NO
Beep when alarm is armed
  • *YES* / NO
Unlock doors via remote
  • DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
  • YES / *NO*
Open/close windows/sunroof/roof via long-press on remote
  • YES / *NO*
Open/close windows and sunroof via smart key
  • YES / *NO*
Open/close windows and sunroof by turning and holding key in door lock
  • YES / *NO*
Auto fold side-view mirrors (req. power folding mirrors)
  • *YES* / NO
Auto fold driver's side-view mirror (req. power folding mirrors)
  • *YES* / NO
Auto fold passenger's side-view mirror (req. power folding mirrors)
  • *YES* / NO
Puddle lights while driver-side mirror is folding
  • *ENABLED* / DISABLED
Puddle lights while passenger-side mirror is folding
Open/close driver's window using single button press
  • *YES* / NO
Open/close passenger's window using single button press
  • *YES* / NO
Open driver's window using single button press
  • *YES* / NO
Open passenger's window using single button press
  • *YES* / NO
Close driver's window using single button press
  • *YES* / NO
Close passenger's window using single button press
  • *YES* / NO
Enable smart key buttons when ignition is on
  • *YES* / NO
Enable remote control when vehicle is running and in gear
  • *YES* / NO
Instruments / Display / Dings
Ding when smart-key ignition is on and door is open
  • *YES* / NO
Ding when headlights are left on
  • *YES* / NO
Lights
Highway lights tilt up above 140 km/h (90 mph)
  • YES / *NO*
Daytime running lights (DRL) brightness when headlights are on
  • 28.000000 <- as a %
Allow configuring daytime running lights via dash display
  • *YES* / NO
Use designated DRL bulbs as daytime running lights
  • *YES* / NO
Use front LED lights as daytime running lights (where applicable)
  • YES / *NO*
Use fog lights as daytime running lights
  • YES / *NO*
Use high beams as daytime running lights
  • YES / *NO*
Use tail lights as daytime running lights
  • YES / *NO*
Use side marker lights as daytime running lights
  • YES / *NO*
Use front marker lights as daytime running lights
  • YES / *NO*
Use low beams as daytime running lights
  • YES / *NO*
Turn off daytime running lights when parking lights are on
  • *YES* / NO
Turn off daytime running lights ("wink") when turn signal is on
  • YES / *NO*
Use front turn signals as parking lights
  • YES / *NO*
Turn on side marker lights with headlights (US models only)
  • *YES* / NO
Coming-home lights
Leaving-home lights
Use fog lights as coming-home lights
  • *YES* / NO
Use low beams as coming-home lights
  • *YES* / NO
Coming-home lights duration
  • *10 SECONDS* / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Ambient light threshold for leaving-home lights
  • 0 / 1 / 2 / *3* / 4 / 5 / 6 / 7
Turn off front fog lights when high beams are on
  • YES / *NO*
Turn off rear fog lights when high beams are on
  • YES / *NO*
Cornering lights (using fog lights)
  • *YES* / NO
Allow configuring footwell lights
  • *YES* / NO
Footwell lights brightness (for cars without extended lighting package)
  • 60.000000 <- as a %
Front footwell lights while driving
Rear footwell lights while driving
  • ENABLED / *DISABLED*
Flash brake lights in emergency stopping
  • *YES* / NO
Flash hazard lights in emergency stopping
  • *YES* / NO
"Euro" parking lights when ignition off, turn signal on
  • YES / *NO*
Other
Auto start/stop system (if equipped)
Auto start/stop system with engine running and driver's door opened (step 1 of 3)
Auto start/stop system with engine running and driver's door opened (step 2 of 3)
  • *DISABLED* / ENABLED (VERSION 1) / ENABLED (VERSION 2)
Auto start/stop system with engine running and driver's door opened (step 3 of 3)
Auto start/stop: remember last state
  • *YES* / NO
Auto start/stop light
  • *ON WHEN SYSTEM INACTIVE* / ON WHEN SYSTEM ACTIVE
ADS (Audi Drive Select) (step 1 of 2)
ADS (Audi Drive Select) (step 2 of 2)
Show engine option in ADS menu
  • *YES* / NO
Show steering option in ADS menu
  • *YES* / NO
Show steering option in ADS menu (2)
  • *YES* / NO
Show suspension option in ADS menu
  • YES / *NO*
ADS mode: individual
ADS mode: comfort
ADS mode: automatic
ADS mode: dynamic
ADS mode: offroad
ADS mode: efficiency
ADS mode: race
Lower passenger-side mirror when in reverse gear
  • *YES* / NO
Remember position when lowering passenger-side mirror in reverse gear
  • *YES* / NO
Lower driver-side mirror when in reverse gear
  • *YES* / NO
Remember position when lowering driver-side mirror in reverse gear
  • *YES* / NO
Headlight washers (if equipped)
Auto-enable rear wiper when front wipers on and reverse gear engaged
  • *YES* / NO
Discussion Starter #3
Carista allows you to do some common customizations....such as disabling Daytime Running Lights, or using different sets of lights to be the DRLs, or rapidly flashing the break lights on a hard/emergency stop...
https://caristaapp.com/
Discussion Starter #5
I thought that was odd too. I guess some of the menu options are carry-overs from generic Audi offerings.
Another two are the "Off-Road" drive select setting and the "Efficiency" drive select setting.
Rear wiper?
Thanks. Their website didn't show it was able to do much so I never hooked it up.
Sent from my SM-G965U using Tapatalk
Discussion Starter #8
Freed up PM.
1 - 9 of 9 Posts
