DIY Oil Change: R8 V8
170695 Views 83 Replies 48 Participants Last post by  Robbe
6
Step-by-step instructions with pictures
Audi recommends changing the engine oil in the R8 only every 10,000 miles (approx. 15,000 km) except for the initial oil change at 5,000 miles. I prefer to change it more frequently than that. For one, I track my car a lot, which does stress the engine. But also, some mechanic friends of mine say that even the best filters can’t keep the small dirt particles out for that length of time, and dirt causes engine wear. I’ve been changing the oil in all my cars for around 4,000 miles. I’ve tracked my NSX hard for about six years; it’s got 140,000 miles on it, and the original engine still runs flawlessly. So, I’ve decided to change the R8’s oil every 5,000 miles. I’ll have to change it once between each scheduled service. It shouldn’t be too harsh, right?
Wrong. The R8 has a dry sump engine, so there's no deep oil pan with a single drain plug. There are three drain plugs in the machine and another in the big oil reservoir, and you have to remove the large plastic noise/aero covers under the car to access it all. You need some special tools to do it correctly. I just changed it for the first time, and it was by far the most challenging oil change I’ve ever done. Here are some notes and pictures to help you if you decide to take this on.
R8 Oil and Oil Filter Change
What parts do I need?
  1. New filter element, Audi part 079-198-405-B, USD 23.47 recently for me at the dealer.
  2. 10 Liters (or 10.6 quarts) of oil. It needs to meet VW502 spec. Audi has published a list of approved oils, which is very long. There are many oils that meet the spec that does not say so on the bottle, including Mobil 1. Here is a link to Audi’s list: https://www.audiusa.com/content/dam/audiusa/Documents/Audi-1997-2016-Technical-Service-Bulletin.pdf
What tools do I need?
  1. 32 MM socket to remove the oil filter cover.
  2. T-30 Torx tool to remove the screws holding on the plastic noise/aero covers under the car.
  3. 8 MM triple square drive tool to remove three plugs from the oil pan. I have an XZN socket set, and this tool is labelled XZN8M. You can remove 2 of the three oil pan plugs using this standard 8 MM tool. To pull the 3rd plug, you need a unique Audi/VW tool, T40159. See more info on this tool later in this thread.
  4. 12 MM triple square drive tool to remove the plug from the oil reservoir, XZN12M. Alternatively, you can use an 18 MM socket, but it’s more challenging because it’s bigger, and there is not much room for it due to the hydraulic clutch line going into the transmission.
  5. A small torque wrench if you want to be sure to re-tighten the plugs to the exact proper tightness.
  6. Ramps or a lift or maybe jack stands to lift the car.
  7. A large pan to drain the oil into.
  8. Oil-proof gloves and a lot of paper towels.
Changing the Filter
This is the easy part. Lift the engine cover, and remove the small center trim piece that says “V8 FSI” by lifting it straight up. Use a big 32 MM socket on an extension to unscrew the filter cover.
The filter canister automatically drains when you remove the filter but have some paper towels ready because the filter drips oil as you remove it. First, yank the old one out of the cap to replace the filter element. Then remove and replace the big o-ring (#2 in the picture) on the lid. Clean the sealing surfaces on the cap and canister, careful not to let any gunk get into the canister. Lubricate the new o-ring with some oil. Insert the new filter into the canister (not into the cap!), turning it until that bottom outlet and o-ring (#4 in the picture) goes into the matching hole in the canister. Press it down firmly. Then screw on the cover until it seats firmly. That’s all.
Changing the Oil
The service manual instructs the engine to be at “operating temperature” before changing the oil. So, run the engine until the oil temperature rises to normal. Don’t you just love working on a hot machine?
Next, get the car off the ground but still be near-level. I have a slight hill in my driveway, so I backed the car up on ramps, and it worked acceptably. A lift would be better as there is little room under the oil pan. Next, use the T-30 Torx tool to remove the 2 (#1 and #2 below) air scoops and the entire rear noise cover (#3). The service manual says to also remove the front nose cover (#4), but you don’t need to; it’s sufficient to remove just the five closest screws on it and pull the edge down a bit when needed. Remember to keep track of where you removed which screws; some have shoulders, others have special washers, others have thread-locking compound, and the rest are plain. Also, note that the two scoops are different from each other and must later be remounted in the proper location. Lots of fun!
Also, you should remove the oil fill cap before draining the oil, so there is good airflow in to allow the oil to flow out quickly.
So at this point, you would see something like this:
Now it’s time to drain the engine oil. There are three drain plugs on the oil pan, clearly marked with large arrows:
Use the 8MM triple square drive tool to remove the plugs and drain the oil. Just position a large catch pan under the plug, grab some paper towels, and have at it. Be careful not to lose those special copper washers on the pins. There are about 4 litres of oil in the engine itself. This is where I ran into a problem. There is very little room for the tool on the one plug close to that red frame member. It’s so close that my socket-type 8MM tool would not work. To get that plug out, you need just the right unique tool. The Audi service manual says to use Socket T40159. So for my first oil change, I didn’t remove that 3rd plug. Later, when I refilled the car with oil, it still took the full 10 litres to fill it, so apparently, there is not a lot of oil left once you drain the engine using only the other two plugs. Afterward, I checked with my local Audi R8 technician, who pointed me to the proper tool. SEE THE T40159 TOOL INFO LATER IN THIS THREAD. When you replace the plugs, don’t over-tighten them. They were not tight; the service manual specifies 20Nm = 14 ft-lbs.
Now drain the oil from the oil reservoir tank. It’s the aluminum tank between the transmission and the left rear wheel above the starter motor:
WARNING – you strike the mother lode of oil when you remove that plug! About 6 litres come gushing out very quickly. Make sure your catch pan is empty and big enough to hold it all and get ready to have your hand covered with (hot) oil. Latex or Nitrile gloves are recommended. Use the 12MM triple square drive tool or an 18MM standard socket. Go for it! Retighten the plug to only 22Nm = 15 ft-lbs.
OK, time to clean up a bit. Grab some soapy cleaner spray, and clean up the clutch line and the giant ground wire from the starter motor covered with oil under the reservoir. Also, clean the bottom of the oil pan. It should look at least as clean as it was when you got there.
Now you’re ready to button it up. As they say, installation is the reverse of removal. Replace all the covers and screws (you kept track of where the special ones went, right?) and scoops.
Up on the top side, pour 10 litres (or 10.6 quarts) of oil into the oil fill location under the oil cap. Start the car and let it warm until the oil temp needle is horizontal (average operating temperature). Then turn off the car and wait 2 minutes. Then check the oil level using the dipstick next to the oil cap. It should be in the “do not add” range; if not, add more until it is. The car should be level when you do this.
That’s it. A nice feeling – happy car, happy driver.
mt
Here's a link to a Microsoft Word format document with this info (441 KB).
See less See more
Reactions: 2
61 - 80 of 84 Posts
here is my special tool - cost just a few dollars and a few min of time:
Use a cut off wheel and cut an xzn bit so that it is just long enough so the other end fits a closed end wrench (an 8mm wrench fit perfectly on the xzn i used)
put the bit in the wrench then insert in the drain plug... Done. Worked perfectly
brilliant!!!
Reactions: 1
Here is my special tool - cost just a few dollars and a few min of time:
Use a cut off wheel and cut an XZN bit so that it is just long enough so the other end fits a closed end wrench (an 8mm wrench fit perfectly on the XZN I used)
Put the bit in the wrench then insert in the drain plug... done. worked perfectly
So, hard to tell in the pic, but was the socket too long to fit in there? Thinking put the wrench on the hex part like you have it, but not cut off the socket - still to long? If so, what size is that? I'll order one for chopping instead of chopping one from my set..
Thx.
Thx.
No way any socket would fit and its such a tight clearance you need to put the bit in the wrench first then insert it into the hole. It is an XZN M8.
See less See more
Thanks! check this out. Can get a whole set with a short bit, so no need to chop and only $13 for the whole set! https://www.amazon.com/Neiko-10078A...ie=UTF8&qid=1495143801&sr=8-1&keywords=XZN+M8.
oil change stuff is on the way already....
Looks like that will work - as long as the bit is short and you use a wrench and not a socket :)
I like the cut-off idea, perfect.
Would this work as well? Better than $50 from stupid Snap-on.
https://www.amazon.com/Powerbuilt-6...121592&sr=1-5&keywords=long+8mm+triple+square[/QUOTE
Wherever you can find the cheapest M8 - you are only going to use about 3/4"-7/8" inches of it anyway after you cut it off
Great instructions!
But someone help here. I was adding oil and the little piece of silver seal on the oil bottle jumped right into the oil filler. ? Fuqk!! No clue what to do here.
2
I got it ? the sad face is because this was a ridiculous amount of work. I could’ve been doing better things. Learn from my mistake.
See less See more
Yes have done Twice, no sweat
great write up, just finished my oil change now for a total of about a $100 bucks mobil 1 0w-40 and filter.
used the cut bit method and wrench pain in the a for sure but quite satisfying getting it off.
i seem to be stuck on the simplest part getting the filter off of the cap! lol
Reactions: 1
Adding to an old thread...got these bits for 5 dollars each. No need to cut.
Edit: you will need to cut the xzn8m bit by a 1/4 inch. Luckily I had a dremel with a steel cutting wheel. The job took about 2 hours with some harbor freight ramps I got for 35 bucks.
See less See more
Step by step instructions with pictures
Audi recommends changing the engine oil in the R8 only every 10,000 miles (approx. 15,000 km) except for the initial oil change at 5,000 miles. I prefer to change it more frequently than that. For one I track my car a lot, which does stress the engine. But also some mechanic friends of mine say that even the best filters can’t keep the small dirt particles out for that length of time, and dirt causes engine wear. I’ve been changing oil in all my cars around 4,000 miles. I’ve tracked my NSX really hard for about 6 years; it’s got 140,000 miles on it and the original engine still runs flawlessly. So, I’ve decided to change the R8’s oil every 5,000 miles. I’ll have to change it once between each scheduled service. Shouldn’t be too tough, right?
Wrong. The R8 has a dry sump engine so there's no deep oil pan with a single drain plug. There are 3 drain plugs in the engine and another in the big oil reservoir, and you have to remove the large plastic noise/aero covers under the car to get access to it all. You need some special tools to really do it correctly. I just changed it for the first time, and it was by far the most difficult oil change I’ve ever done. Here’s some notes and pictures to help you, if you decide to take this on.
  1. New filter element, Audi part 079-198-405-B, $23.47 USD recently for me at the dealer.
  2. 10 Liters (or 10.6 quarts) of oil. It needs to meet VW502 spec. Audi has published a list of approved oils, and that list is very long. There are many oils that meet the spec that do not say so on the bottle, including Mobil 1. Here is a link to Audi’s list: https://www.audiusa.com/content/dam/audiusa/Documents/Audi-1997-2016-Technical-Service-Bulletin.pdf
  3. 8 MM triple square drive tool to remove 3 plugs from the oil pan. I have an XZN socket set, and this tool is labeled XZN8M. You can remove 2 of the 3 oil pan plugs using this standard 8 MM tool. To remove the 3rd plug, you need a special Audi/VW tool T40159. See more info on this tool later in this thread.
  4. 12 MM triple square drive tool to remove the plug from the oil reservoir, XZN12M. Alternatively, you can use an 18 MM socket, but it’s more difficult to use that because it’s bigger and there is not much room for it due to the hydraulic clutch line going in to the transmission there.
  5. A small torque wrench if you really want to be sure to re-tighten the plugs to the exact proper tightness.
Changing the Filter
This is the easy part. Lift the engine cover, and then remove the small center trim piece that says “V8 FSI” by lifting it straight up. Use a big 32 MM socket on an extension to unscrew the filter cover.
The filter canister automatically drains when you remove the filter, but have some paper towels ready because the filter drips oil as you remove it. To replace the filter element, first yank the old one out of the cap. Then remove and replace the big o-ring (#2 in the picture) on the cap. Clean the sealing surfaces on the cap and canister, being careful not to let any gunk get into the canister. Lubricate the new o-ring with some oil. Insert the new filter into the canister (not into the cap!), turning it until that bottom outlet and o-ring (#4 in the picture) goes into the matching hole in the canister. Press it down firmly. Then screw on the cover until it seats firmly. That’s all.
Changing the Oil
The service manual instructs that the engine should be at “operating temperature” before changing the oil. So, run the engine until the oil temperature rises to normal. Don’t you just love working on a hot engine?
Next, get the car off the ground but still be near-level. I have a slight hill in my driveway, so I backed the car up on ramps there and it worked acceptably. A lift would be better as there is not much room up under the oil pan. Next, use the T-30 Torx tool to remove the 2 (#1 and #2 below) air scoops and the entire rear noise cover (#3). The service manual says to also remove the front noise cover (#4) but you don’t need to; it’s sufficient to remove just the 5 closest screws on it and pull the edge of it down a bit when you need to. Remember to keep track of where you removed which screws; some of them have shoulders, others have special washers, others have thread locking compound on them, and the rest are plain. Also note that the 2 scoops are different from each other and must later be remounted in the proper location. Lots of fun!
Also, you should remove the oil fill cap before draining the oil, so there is good air flow in to allow the oil to flow out quickly.
Now it’s time to drain the engine oil. There are 3 drain plugs on the oil pan, clearly marked with large arrows:
Use the 8MM triple square drive tool to remove the plugs and drain the oil. Just position a large catch pan under the plug, grab some paper towels, and have at it. Be careful not to lose those special copper washers on the plugs. There’s about 4 liters of oil in the engine itself. This is where I ran into a problem. There is very little room for the tool on the one plug that is very close to that red frame member. It’s so close that my socket type 8MM tool would not work. To get that plug out, you need just the right special tool. The Audi service manual says to use Socket T40159. So for my first oil change, I didn’t remove that 3rd plug. Later when I refilled the car with oil, it still took the full 10 liters to fill it, so apparently there is not a lot of oil left once you drain the engine using only the other 2 plugs. Afterward I checked with my local Audi R8 technician, and he pointed me to the proper tool. SEE T40159 TOOL INFO LATER IN THIS THREAD. When you replace the plugs, don’t over tighten them. They were not super tight; the service manual specifies 20Nm = 14 ft-lbs.
Now drain the oil from the oil reservoir tank. It’s the aluminum tank between the transmission and the left rear wheel, above the starter motor:
WARNING – you strike the mother lode of oil when you remove that plug! About 6 liters comes gushing out very quickly. Make sure your catch pan is empty and big enough to hold it all, and get ready to have your hand covered with (hot) oil. Latex or Nitril gloves are recommended. Use the 12MM triple square drive tool, or an 18MM standard socket. Go for it! Retighten the plug to only 22Nm = 15 ft-lbs.
OK, time to clean up a bit. Grab some soapy cleaner spray, and clean up the clutch line and the big ground wire from the starter motor that just got covered with oil under the reservoir. Also clean the bottom of the oil pan. It all should look at least as clean as it was when you got there.
Now you’re ready to button it up. As they say, installation is a reverse of removal. Replace all the covers and screws (you kept track of where the special ones went, right?) and scoops.
Back up on the top side, pour 10 liters (or 10.6 quarts) of oil into the oil fill location under the oil cap. Start the car and let it warm up until the oil temp needle is horizontal (normal operating temperature). Then turn off the car and wait 2 minutes. Then check the oil level using the dipstick there next to the oil cap. It should be in the “do not add” range; if not, add more until it is. The car should be level when you do this.
mt
First of all great write-up!
I have some info I wanted to add, not sure if it's better to start a new thread or if you're still updating this one:
Here's some info that I'm sure everyone will find helpful so that you don't strip the pan (READ UNTIL THE END)
First I figured I would include the specs for the oil filter cap, which are:
Oil filter cap = 25Nm
Secondly it's worth noting that I believe Audi is ending production of new oil pans for v8 from what I've gathered. I am not sure offhand the last production year of the v8, but typically manufacturers will make a part 10 years after the last production date. More of an FYI, but I could be wrong.
Finally can we all verify the oil drain pan torque specs:
This thread has been around for so long that I assume there's a reason for it, but why are you torqueing the drain bolts to 20Nm instead of 10Nm????
- What am I missing, the 3 oil drain plugs should be 10Nm right?
- Now it could be one rating is for dry, and another for with some oil on the threads (bolt itself or pan threads).
Note: the pan itself says on it 10Nm or this very reason.
Also worth noting for the V8 the OEM oil pan has been through a few updates :)
The original part number on early v8's ends in a D, which I have, and I think you do too (hard to see from the pic)
Anyway my pan (2008), ends in a D:
- Doesn't have the arrows pointing to the 3 plugs
- Doesn't list the torque specs
- Doesn't have the special cutout on the passenger side bolt
Your pan, which looks to end in a D, not sure what year it is, anyway
- Does have the arrows pointing to the plugs
- Does have the torque specs of 10Nm
- Looks like it doesn't have the special cutout on the passenger side bolt
Anyway I just picked up a new oil pan from audi ending with F
- Has the 3 arrows
- Has the torque specs ot 10Nm
- Has the special cutout on the passenger side bolt
The special cutout helps when torqueing this bolt if you're using a triple socket set. The socket part hits the edge if it's not cutout, which is why the torque spec and knowing that this could rub if you have the older version of the pas is so important, especially if they stop making the pans.
If you have a pan without the cutout (blue) you may want to think about grinding that part down for a better fitment when a socket is used.
Maybe even show this pic to audi and have them grind it out if you're having a recall done or any work :) can't hurt to ask!
264499
Thanks!
Steve
See less See more
I did mine a few months back, was simple but time consuming and I didn’t use any special tools, the one where you need the specialist tool, I used a plumbers wrench, a tiny one
Plumbers wrench can lock on to a round head so it will always work, obviously you can’t torque it to spec but it doesn’t require any force, don’t over do it and you’ll be fine
264501
See less See more
Hi
Why don't they offer the oil drain screws with an external hexagon head? could be produced very quickly with a CNC machine.
Tom
OP. Excellent post.
Interesting commentary and experiences follow your info.
i currently have my car up on the lift, removed the engine cover, looking around and cleaning things as i go..
Will look into how to remove the rear bumper cover if / when I add a more vocal exhaust.
Can anyone point me to a good exhaust DIY. Car is 2014 V*.
Craig
There are a few PDFs knocking about. Here's a couple from Fabspeed and Stasis. I think the process is pretty much the same for V10 and V8 so have a read through and see which one is easier to follow as I can't remember now which one I used as a guide.
61 - 80 of 84 Posts
