Hi,
Worst case scenario should deliver 706hp, assuming that head porting and other variable have no effect.
If the math is correct and all variables translate into tangible hp, the build should deliver between 742 -757 hp.
The numbers in the table below were calculated based on the verified numbers, weight, hp, etc. After the calculations were complete and reproduced/matched each verified figure, I simply updated the hp, weight, power, torque and increased RPM in the calculated column. This the allows me to generate scenarios, based on perfect conditions, in the calculated column.
| Verified
LMS R8 v10 | Verified
R8 v10 GT | Verified
R8 v10 Perf | Verified
R8 v10 Manual | R8 v10 Manual | calculated R8 V10 Manual | calculated R8 V10 Manual | calculated R8 V10 Manual 12.5 | calculated R8 V10 Manual 13.1 | calculated 12.5 R8 V10 Performance % increase | calculated 13.1 R8 V10 Performance % increase |
Weight | 1250.0 | 1525.0 | 1595.0 | 1620.0 | 1620.0 | 1554.5 | 1525.7 | 1525.7 | 1509.1 | 0.94 | 0.93 |
HP | 560.0 | 560.0 | 611.5 | 520.0 | 593.2 | 601.4 | 610.2 | 631.7 | 757.3 | 21.48% | 45.64% |
TQ | 398.3 | 398.3 | 428.0 | 391.0 | 461.9 | 469.7 | 476.0 | 490.5 | 505.7 | 25.46% | 29.33% |
0-62 MT time | 3.0 | 3.6 | 2.9 | 3.6 | 3.1 | 3.0 | 2.9 | 2.8 | 2.2 | -23.55% | -39.39% |
0-124 | 10.8 | 10.8 | 9.0 | 11.5 | 9.9 | 9.2 | 8.9 | 8.7 | 7.0 | -24.66% | -39.39% |
Top Speed | | 201.0 | 206.0 | 197.0 | 197.0 | 200.9 | 200.9 | 200.9 | 219.6 | 1.96% | 11.49% |
124-0 MT time | 103.4 | 126.1 | 131.9 | 134.0 | 134.0 | 128.6 | 126.2 | 126.2 | 124.8 | -5.82% | -6.84% |
62-0 MT time | 84.1 | 102.6 | 107.3 | 109.0 | 109.0 | 104.6 | 102.7 | 102.7 | 101.5 | -5.82% | -6.84% |
rpm red/line | 8700 | 8700 | 8700 | 8700 | 8700 | 8700 | 8700 | 8700 | 9700.0 | 0.00% | 11.49% |
