Forza Controller gives you 3 modes: Locked open, closed and OEM. It is plug and play, however, the one I installed had 2 wires crossed inside the unit which we found by trial and error. Was a PIA, but we finally got it sorted out and it works great.
That's pretty awesome. Do you have the installation instructions or anything you can share? The plug and play with OEM features still in tact is ideal.Forza Controller gives you 3 modes: Locked open, closed and OEM. It is plug and play, however, the one I installed had 2 wires crossed inside the unit which we found by trial and error. Was a PIA, but we finally got it sorted out and it works great.
Install should be like the valvetronic. My local Audi mastertech did the install. Went through the passenger side rear wheel area. Should be a pretty simple install. The unit comes with a remote with 4 buttons. A = locked open B = OEM C & D both = locked closed. To be honest, with OEM sport exhaust, it will always be locked open. I really thought I was going aftermarket exhaust when I first got the car a bit over a month ago, but I'm really liking it with the controller now and I've decided to stick with stock exhaust for now. Not sure if it's just me or not, but at 400 miles, the car seems to be sounding better and better.That's pretty awesome. Do you have the installation instructions or anything you can share? The plug and play wit OEM features still in tact is ideal.
When you press button B = OEM. Does that mean when you select Comfort drive mode, exhaust is closed like OEM? Can you still use the exhaust button on the steering wheel?Install should be like the valvetronic. My local Audi mastertech did the install. Went through the passenger side rear wheel area. Should be a pretty simple install. The unit comes with a remote with 4 buttons. A = locked open B = OEM C & D both = locked closed. To be honest, with OEM sport exhaust, it will always be locked open. I really thought I was going aftermarket exhaust when I first got the car a bit over a month ago, but I'm really liking it with the controller now and I've decided to stick with stock exhaust for now. Not sure if it's just me or not, but at 400 miles, the car seems to be sounding better and better.
You are correct. Can still use the exhaust button. Everything is as from the factory.When you press button B = OEM. Does that mean when you select Comfort drive mode, exhaust is closed like OEM? Can you still use the exhaust button on the steering wheel?
i tested it more this week.Ah I see. I’m looking to have valves open 100% of the time, or revert back to OEM. So valvetronic isn’t for me.
It is so much easier from the fender well. I tried from the top and hell no it’s so far
Down and there are two solenoids. The second one or in the pic the right one is where I took power from for new controller and my controller came with its own solenoid.
What is the second solenoid for ?View attachment 274104
I start the car with closed valves with the programmable CETE.Is it possible to start the car with closed valves? Im mainly looking for the option to have the cold start as quiet as possible.... ( aftermarket exhaust)
How does this work? Do you need to do a manual operation before u start the car or is it programmed to start with closed valves?I start the car with closed valves with the programmable CETE.
you program it with your phone over bluetooth so you can set it and forget it.How does this work? Do you need to do a manual operation before u start the car or is it programmed to start with closed valves?
And when you hit the exhaust button on the steering wheel? Does it work than or you need to use the app?you program it with your phone over bluetooth so you can set it and forget it.
I have it closed in Comfort up to 5k rpms and it opens
Auto is closed at idle, opens at 2 mph and closes again at 60 mph (for quiet on highway) and opens at 5k rpms again
Dynamic is always open
I can change any of those parameters by mph or rpm anytime i want with the phone app. It's really cool.
You don't use the app except to program the modes as mentioned above. After that, changing the modes changes the exhaust valve positions.And when you hit the exhaust button on the steering wheel? Does it work than or you need to use the app?
Did you ever receive any responses?Hey everyone. New here with 2022 RWD.
I was looking to get a valve controller installed but was told by my dealer it would void the engine warranty. Was anyone told that as well?
