1 - 11 of 11 Posts
guys,
does ur front LED lights stay on in the daytime? all the pics i've seen the lights stay on in daytime i thought it's daytime running light(DRL). mine is off unless i turn the driving light on. is DRL programmable? just curious.
Yes, you have to go into the MMI and program them--at least that is what I had to do--then they are on as DRL. I don't remember the steps, but it can be done this way.
Discussion Starter · #4 ·
hummm jet, i looked again but didn't find anything in the MMI where i can set the LED. are u sure it wasn't done at the dealer?
TIA
I didn't drive my car to work today, but I thought you could switch this easily on the setup or other menu in the little red box in the instrument cluster (along with how long to leave your lights on, chime for lock and unlock, etc.).
I can control it through my DIS
theres a button under the wiper blades control stalk. Press this and you will see the DIS change from stop watch, digital speedo, etc. Keep pressing until you see a setup menu. The lights can be programmed here!
Discussion Starter · #10 ·
thanks!!! just did it.
1 - 11 of 11 Posts
