1 - 11 of 11 Posts
Does anyone have any info on how to remove the steering wheel airbag cover on a Gen2? Or maybe a link to a video. I can't seem to find one specific to a Gen 2 or any instructions.
Thank you :)
Discussion Starter · #2 ·
No need - I found one
Discussion Starter · #5 ·
Can you share what you found
It's not the greatest video but it gives the basic idea how the cover is attached to the aribag mechanism. I sharpened one srewwdriver and was able to do this fairly easily.
Discussion Starter · #6 ·
Here are a couple pics of the finished product.
Automotive tire Automotive lighting Motor vehicle Automotive design Gas
Automotive tire Wood Automotive design Rim Motor vehicle
Discussion Starter · #7 ·
Here is the complete wheel installed. The red stitching goes great with my red diamond stitched seats.
Motor vehicle Automotive design Audio equipment Gadget Auto part
looks great! Who made the wheel?
What paddles are those?
Did you have the airbag re done with the red stitch? If so, how does that affect if the airbag goes off?
Discussion Starter · #9 ·
The wheel and airbar cover was supplied by askcarbon. You can find them on instagram or FB. The paddles are copies from a Urus. Just remove the old paddles and these fit right in using the oem elecronics. The complete aribar cover was replaced with a new cover and I ordered it with the red stitching. I still have the old oem one. It won't affect the airbag deployment.
That’s who I ordered from too. I didn’t like the Urus paddles but now that I see yours I do like them. They made me a custom paddle that was 3cm shorter than their typical long carbon one.
So you take the guts out of your OEM paddles and put them in the paddles they supply? Is that how it works?
Discussion Starter · #11 ·
Once you have the OEM paddles off the steering wheel, there is a metal pin that needs to slide out. Remove the pin and the paddle comes away from the electronic part. Put the new paddle on and slide the pin back in. The pin acts as a hinge. Be carful when you pop off the silver trim and control buttons. There are wires underneath that need to be disconnected that run to the paddle shifter.
1 - 11 of 11 Posts
