4 more sets back in stock
Only front bumper canards, side skirt extensions and rear bumper canards.Is this variant 2 of the OEM performance parts?
Do you sell the complete variant 1 package? (including the wing)
Can you please tell me how you secured these? It won’t grab. I got 19mm t25 bolts. Thank youThanks Shardul for the fitting advice and excellent service.
I really like the way the lower rear extensions complete and accentuate the carbon diffuser and side skirts:
They look even better on the car!
I have 20mm long screws but haven’t installed yet. I didn’t want to get anything much deeper, because I’m not sure what’s beyond the bumper cover that I might not want to drill into. Don’t these just secure to the bumper cover?Can you please tell me how you secured these? It won’t grab. I got 19mm t25 bolts. Thank you
im interested send me a DM on IG r8_ryan2 sets left in stock
On mine, I removed the tape that came pre-installed because a.) it wasn't installed "correctly" and b.) I fully wrapped it in PPF to prevent rocks from chipping it. I bought my own 3M acrylic foam tape, properly prepped the surface using alcohol wipes, and 3M's adhesion promoter for acrylic foam tape. Originally, I didn't want to drill holes in the rear bumper cover, but it actually ended up making installation easier.I just bought a set of these! Can someone please shed some light on how to install these? There's no instructions, Im not ready to just start drilling holes. Thx in advance.
First, I didn't use the **** hardware that came with these. They're lightly covered in some black paint, but I'm sure they'd rust over time. I ended up getting some PVD coated titanium screws for the install. We test fit the piece aligning it in the desired location. Used a punch awl to mark the hole for drilling on the cover. We drilled two 1/8" holes for the titanium hardware per side (i.e. that hole dimension will change based on the hardware that you decide to use. There needs to be enough plastic for the screw to bite and tighten). After this, I prepped the bumper by cleaning with a soapy water solution to remove residual wax, rinsed the areas with water to remove the soap, and then used a final alcohol wipe to make sure that the surface was devoid of any remaining chemicals. Then, we removed corners of the release liner on the 3M tape folding it back and taping it to the CF piece with Painter's Tape so that you can access it just prior to making contact with your bumper. You don't want to fully remove the release liner in case you make contact with your prepped bumper. Once it sticks, it's incredibly difficult to reposition if you've done all your prep steps correctly. We then floated the CF piece just underneath the bumper so that we could start driving in the titanium hardware. As we started getting the piece close to the bumper, we removed all the remaining release liner and then continued to screw it down until full contact was made between the 3M tape and the plastic bumper, then pushed around the perimeter for good measure.
Wait 24-28 hours for a full tape wet out before you really start driving at high speeds. During this time period, bond strength will increase to 95% of maximum hold strength.
