thanksBase plate comes primmed from Audi. It needs to be painted.
Dumb question. If you can simply pull a fuseFinally, thank you for the post/write-up!
Dumb question. If you can simply pull a fuse and directly mount the wing. Then why go through the hassle and cost of buying the full replacement kit?What you see on this pic is $1600 from the Audi dealer. I'm sure you can source those parts online even cheaper. The most expensive part is the carbon wing itself - I have bought one used (for another $1600) from a person upgrading to the bigger Vorschteiner spoiler. So $3200 total in parts.
Because some people want it to be OEM like I suppose.Dumb question. If you can simply pull a fuse
1. To make it OEM not some ghetto style.Dumb question. If you can simply pull a fuse and directly mount the wing. Then why go through the hassle and cost of buying the full replacement kit?
Agreed if you are mounting the OEM wing. And I may end up buying a used one.1. To make it OEM not some ghetto style.
2. The retractable spoiler is not as solid as fixed mount and after you load it with a spoiler on top, you can see it rattles a bit at speed.
What wing are you considering?Agreed if you are mounting the OEM wing. And I may end up buying a used one.
However the wing I'm considering is non OEM, and made to fit on the non plus base plate.
I bought a used 2017 plus OEM wing. So I will do the full conversion.What wing are you considering?
Sounds good. I did the same for my 17 base but did not do the full conversion. We did the fuse and coding and works just fine. I understand wanting to do the full conversion I was thinking about doing it that way too but did not want to spend the outrageous amount for all the partsI bought a used 2017 plus OEM wing. So I will do the full conversion.
One of the vendors sells an aftermarket OEM replica that is mounted directly to the non plus base plate. Only $900 plus install. However I decided to go the long, harder, and more expensive route with the full swap.
this is awesome. I just bought a plus wing, and will need to replicate this. thank you for posting these steps!I just did the NON-PLUS (RWS) to PLUS spoiler conversion so I did not need to pull the fuse. I went with a Vorsteiner style spoiler. For those of you that want to code the spoiler error out yourself, it's very easy with OBDeleven tool. Here are step by step instructions
1. Purchase OBDeleven Starter Tool from Amazon
2. download OBDeleven app on iOS
3. log in, create account, upgrade to PRO account (need this to long code)
4. connect to vehicle per instructions provided
- plug in reader, start car (not engine), connect via bluetooth on App
5. Vehicle -> Control Units -> Comfort System (Control Unit 46)
- Long Coding -> Search "Spoiler" -> Click radio button "NOT INSTALLED" -> Slide to Write
6. Vehicle -> Control Units -> Dashboard (Control Unit 17)
- Long Coding -> Search "Spoiler" -> Click radio button "NO" -> Slide to Write
when you want to go back to stock NON-PLUS from PLUS conversion, just do it backwards
photos included as well for those that may need it.
best of luck, it's one of my favorite mods thus far! totally changes the way the car looksthis is awesome. I just bought a plus wing, and will need to replicate this. thank you for posting these steps!
Is that USD?$1600-2000 for the OEM fixed wing mounting hardware (depending where you shop) + the wing.
The CF wing is super expensive @ $7k or thereabouts, but you can easily buy one used from someone switching from OEM to Vorsteiner wing. I have paid $1600 for mine in as new condition.
I have also paid $1600 for the mounting hardware, so for me it was $1600 + $1600 + $500 labor (paint job and installing all bits) = $3700.
I would rather do it outside the Audi dealership unless you have a good relation with them. Once you put it in, I'm pretty sure they will not notice, as every 2nd R8 is a Performance model with a wing, so it is next to impossible to tell (unless you check the car's papers).
Were you able to code on your 2021? My OBDeleven doesn't show an option for any coding. Something about how they are still negotiating with Audi to be able to access the coding for 2020 and newer.For those that like me are upgrading from the retractable spoiler to the CF wing using all original Audi hardware (i.e NOT installing your new spoiler on top of the old retractable one, but rather going full OEM route).
There is no need to remove the fuse as the motor is removed with the old mounting plate when installing new plate for the CF wing. So you can skip step # 1 and go straight to step # 2/3 (coding).
You will have to wait unfortunately. Otherwise, you can find someone with Vagcom willing to help or disconnect the wing shaft mechanism.Were you able to code on your 2021? My OBDeleven doesn't show an option for any coding. Something about how they are still negotiating with Audi to be able to access the coding for 2020 and newer.
Got it. Thanks!You will have to wait unfortunately. Otherwise, you can find someone with Vagcom willing to help or disconnect the wing shaft mechanism.
Hi GuysI just did the NON-PLUS (RWS) to PLUS spoiler conversion so I did not need to pull the fuse. I went with a Vorsteiner style spoiler. For those of you that want to code the spoiler error out yourself, it's very easy with OBDeleven tool. Here are step by step instructions
You can always go the other route of keeping the spoiler enabled, but disconnecting the drive in the motor, so the car still thinks the wing is coming up.Hi Guys
I have a 2018RWS which is extensively tracked. It has an LMS Gt4 fixed rear wing fitted. I left the old spoiler motor installed and electrically connected and everything was good for 2 years or so. Recently I started to get the rear spoiler not deployed correctly error message. So I coded out the rear spoiler as per the instructions above. The problem is that now every time I go over 100mph on track the traction control reactivates. Obviously on track the traction control has to be off and stay off otherwise the car is rubbish to drive. I did some research on the R8 Plus with the fixed spoiler and it appears that this may be part of the Audi software and not possible to code out? Any experience out there? I just need to get rid of the spoiler not deployed error message without the car altering the traction control setting.
That method does work and was the preferred method before I did the fuse/vcds disable method. You just disconnect the drive shaft mechanism so the car will raise and lower as though it thinks the wing is still there. There's no sensor that checks to see if anything actually got raised. You shouldnt be getting any more errors after that.Hi Apolloski. I have run it for 2 years with the motor connected and the spoiler enabled. However I did keep getting the random messages that the spoiler was faulty, these were steadily becoming more and more frequent. They could usually be cleared and it was all good again for a while. As it is getting more frequent I was hoping for a method of coding it out which did not cause the traction control to re-enable above 100mph? I am not sure that leaving the spoiler enabled but disconnecting the drive in the motor will work? I guess that it looks for some limit position in the motor to determine if the spoiler is at the end of its travel up or down? I would assume that it will throw a fault code all the time? Happy to give anything a try, its ruining a great car.
Pull out the fuse and recode.Hi Apolloski. I have run it for 2 years with the motor connected and the spoiler enabled. However I did keep getting the random messages that the spoiler was faulty, these were steadily becoming more and more frequent. They could usually be cleared and it was all good again for a while. As it is getting more frequent I was hoping for a method of coding it out which did not cause the traction control to re-enable above 100mph? I am not sure that leaving the spoiler enabled but disconnecting the drive in the motor will work? I guess that it looks for some limit position in the motor to determine if the spoiler is at the end of its travel up or down? I would assume that it will throw a fault code all the time? Happy to give anything a try, its ruining a great car.
