101 - 105 of 105 Posts
· Registered
2018 Audi R8 Daytona Grey
Quick tips, here is what i did. 1st pull fuse and only need to long code out instrument cluster. Also add the rubber feets rubber bumper pads prevent loose plate feel. View attachment 281110
Can you try something for me? Can you hold the traction control button for 5 seconds so it turns off both TC and ESC. After both are off can you try and go above 100mph and let me know if ESC turns back on?
The issue I am running into is when I hit 100mph ESC automatically turns back on.
· Registered
2017 r8 base, upgrade to plus oem wing
Pulled fuse out, vcds cancelled both 17 and 46
On 168km/h traction kicks back on
Any idea anyone ?
I get this fault on abs which can’t be removed by some reason -
Wednesday,15,March,2023,16:43:55:53368
VCDS Version: Release 23.3.0 (x64) Running on Windows 11 x64
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 4H0-907-379.clb
Control Module Part Number: 4S0 907 379 D HW: 4S0 907 379 D
Component and/or Version: ESP PREMIUM H09 0300
Software Coding: 01A1810B808581D04B00
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004048 (AU72)
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3E2E556910FAB27A3DF-806A
Fault Codes have been Erased
1 Fault Found:
0668 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_HSP_01_Timeout]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 57591 km
Date: 2023.03.15
Time: 16:43:32
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 99
