That BISL number is just the dimensions of the seal (ID-OD-Depth), not a part number as such. I found high temperature seals in that size very hard to track down, hence trying one 5mm thick rather than 4mm.
You can see how that fits in the photo's above, it's a good tight fit and I'd definitely recommend using a press to make sure its pushed in square. I did put a bit of Loctite around the outside as well just to make doubly sure it wasn't going anywhere. No leaks from it thus far so I'd say it works.
I did get two so can always just pop one in the post if you'd like to try it as well?
