Do you find it's annoying that any speed over 50 MPH you get some annoying sounds from the wind in the cabin?
Well NO MORE!!! For $30 and 30 minutes of your time it's gone.
Kudos to MAR8 for showing me how to do this. It's buried in a different thread about track days posted here but this is definitely deserving of it's own thread. I slightly tweaked his directions but the original thread I linked just above. The areas I edited/added I put in BOLD.
Buffet Buster install guide!
Here is what you want: Wiper blade is about $20 and the tape is around $8. I am figuring everyone else has the remaining tools. Unlike his guide I used a sharpie pen instead of a pencil to mark the cutting on the 3M tape.
You can source this wiper at Advanced Autoparts. Buy this length and you’ll have plenty of wiper for both sides. If you can’t find this wiper, any good wiper with an airfoil will do. You’ll just find that some are not solid rubber like this one and are molded in an arc to form the airfoil, like this:
Just build up a couple layers with the tape to fill the void and don’t cut the slots off. The rest of this guide still applies. Personally for mine I just used one layer of 3M tape on my car (Ara Blue Crystal photos at bottom).
Start by removing the end caps with needle nose pliers.
Then slide the airfoil out.
You’ll see there are slots on each side of the airfoil. Carefully cut them off to create a good flat surface for the tape to adhere to. I like this wiper because the width is identical to the width of the tape. This process is a bit time consuming. I used a mix of a scissor and the razor to try and get it to look nice. I also filed it down as well to make it smooth..
Go ahead and apply the tape, leaving the outside still covered.
Now you can head to the car to make some pencil marks that will determine the angles to cut. Open the hood for this. You’ll see that there is a natural line on the bottom of the A pillar trim. Use that as a guide and mark the airfoil. I did not install it where he installed it. He installed it on the actual paint trim which required opening the hood. This is optional. I also did not use a pencil but rather a sharpie on the actual red area of the 3M tape to mark where to cut. I cut the piece a tad larger than necessary so I could simply trim it down and test fit the part. See photo with the arrows as to where I put mine compared to his
Using the utility knife, cut the end to match the marks.
Now do the same with the top part. Make sure you have the bottom lined up and then mark the top. I like to follow the line created by the window triangle trim piece. Cut it and test fit to ensure your angles are spot on.
Carefully peel the protective layer off using the utility knife. Don’t pry the very top. Pry the lower portion of the angle to maintain a better adherence in that tiny top corner.
Head back to the car and wipe the trim so you have a clean surface for the tape. Carefully affix it to the trim.
Close the hood and see if you need to trim anything. I needed to cut a small little section for a perfect fit.
You’re done! Repeat on the other side and enjoy buffet free driving!
For my final set of directions, I started installing the piece from the TOP and worked my way down. I only pulled off a small piece of the 3M tape to get it to stick on the top. I then gently tugged the 3M tape downward allowing me to slowly mold the airfoil onto the body panel. My final product is as seen below. You can use the first one you made as a guide to quickly make the second piece. The second piece is essentially a mirror image of the first. .
Cool trick, but all you need to do is just roll the window up a couple inches. Not a big deal. Better then taping a hacked up windshield wiper off the side of your $200K car.
More like rolling it up more than halfway. I've tried multiple positions with no success in terms of window positions that are anywhere near close to being mostly open. On a 200k car I'm surprised this wasn't hashed out in R&D for Audi. Even the Porsche 911 another pricey car same issue. Yet my GT-R at half the price and my half price C7 and C6 Vettes I had before this was a non-issue with wind buffeting. Basic window functioning on a 2 door car should have basic function of windows rolled down all the way and be buffeting-free. I get it on a 4 door/4 window car things are a bit more challenging but a simple 2 door/2 window car that's unacceptable. I find on the actual black triangle body part it certainly does not look like some hacked on product in person. It looks like a part of the OEM trim.
Now the AWE parts available for Porsche (and it seems like soon to be us) looks like some tacked on piece and is glaringly obvious on the car. In addition, no respect to MAR8, but on the actual door trim I think it looks a bit more obvious like a tacked on part. Installing on the black triangle trim piece it looks OEM to me. If this doesn't look OEM I don't know what to tell ya...to each their own. My photo below I think it blends in nicely.
Now the AWE parts available for Porsche (and it seems like soon to be us) looks like some tacked on piece and is glaringly obvious on the car. In addition, no respect to MAR8, but on the actual door trim I think it looks a bit more obvious like a tacked on part. Installing on the black triangle trim piece it looks OEM to me. If this doesn't look OEM I don't know what to tell ya...to each their own. My photo below I think it blends in nicely. <img src="http://www.r8talk.com/forums/images/smilies/cool.png" border="0" alt="" title="Cool" class="inlineimg" />
Well, it looks like a small windshield wiper is stuck to the side of the car.
Literally, it looks pretty **** stupid if you ask me.
But I guess your opinion will supercede mine, to you, so why do I bother to state mine? Lol.
As long as it works for you, who cares what I think. Id rather have the wind buffeting instead. Just like I'd rather have nice looking wheels instead of putting covers on them to get better MPGs.
I still suspect the engine bay hatch for the noise, can't help it. Didn't have this buffeting sound for the first 10000 km or so and after a very hot day (almost 40°C), the buffeting started and never went away. I suspect that the excessive heat from the weather and the engine kind of caused the engine bay hatch to "deform" a little bit or maybe just the sealing (is there any? I guess so...). Always forgot to tell my mechanic when my car was at the repair shop but will do that next time. Let's see if there is a better solution.
From years of personal experience with this, no one ever notices it and when I point it out, they all say it look like part of the car. I mounted it on the window trim on the R8 just like I did on the TTRS. It blends seamlessly on my black car but the triangular piece is even better. I did a prototype test of this at the track and it worked beautifully so I stuck with the original and tested position. I may move it but as stated earlier, no one ever notices it. On the other hand, everyone notices the fake upper intake on the Gen 2. Audi should have done more with it than just a cheap plastic cover with honeycombs molded on it. Really?!?!?!
I gotta give this a try. Agree, buffeting is horrendous in this car ( I have a Gen 1) so if this does the trick its well worth it to me. Thanks for taking the time to show how to get this done.
Strange, not a single person has ever noticed the "fake upper intake" on my R8. I've been to countless rallies, cars and coffee, 1/2 mile races, etc. My buddies have inspected the car closeup multiple times and never commented on it.
But, a piece of a windshield wiper stuck onto the car?
Hahaha, give it a try and see what happens. It could be that the OCD Ferrari guys that frequent our C&C's are sticklers for details like that. They also dislike the off center engine placement and wondered if that would be "corrected" in the RWS series.
Seriously? I think he did an amazing job and it looks oem. This is something that is definitely needed. Go back to your Cali forums and sip your venti Starbucks while you pay over inflated taxes along with being stuck in traffic and hugging trees... douche
Well I got a chance to test it on the highway. All speeds great I tested up to about 115 MPH. No buffeting. It works great where I installed it on the triangle.
As much as I love black cars, I hate them even more when they are dirty.
So I had my detailer wrap the whole car in Matte PPF and Gloss on the carbon fiber. Perfect for the snowy and salt covered roads in NJ.
I know my hood is up in the pictures.
Next mod, is installing the titanium exhaust B...
New member. Have always admired the R8, but never owned one. Have owned so many other Audi’s and other supercars and thought why not.
Was at my dealer getting the first service on my 991.2 GT3 manual and this 2020 R8 was there and couldn’t resist. Our went the GT3.
Here are some pics.
