Lol don't even think of that.Otherwise Alibaba will come into the mix and pollute everything!
Hi guys,
We often get asked for small maintenance, service and repair items. Our business model is not really set up for this - handling small items is fiddly and time consuming.
Also some repair options for more expensive items
We thought it might be useful to set up a money saving tips thread - where owners can be pointed to where they can buy common items and not pay the dealer price.
The more you save on the boring stuff - the more you can spend on the fun stuff with us!
We are only posting where the identical parts to OEM can be bought for less by not buying from Audi.
We are not suggesting any OEM replacements or alternatives
We will slowly add to this.
1. Gen 1 A/C compressor
Dealer price is $1,569.23
You can buy the identical compressor from Denso for less than $450
Denso ref 471-1505
2. Gen 1 V8 and V10 Ignition Coils (pre-facelift excluding GT)
Dealer is $63.33 each
Buy the same part from Bosch ref 0221604800
Will cost you around $30 each
3. MAF sensors
Dealer is $330 each
Buy the same part from Hitachi ref MAF0057
Will cost you around $120 each
4. Gen 1 V8 xenon headlight bulb
Stealership wants $193 for this
You can buy from Phlips ref 85415C1
Less than $50
5. Faulty ECUs
Stealership wants around $4,000 plus an install fee
Use a repair service - probably less than $1,500 for the two with a lifetime guarantee
Repair services can send you them back and you just plug them back in - no dealership involved
6. Faulty R-Tronic hydraulics
A new unit will cost you around $4,000
A professional overhaul around $2,000 - and they will use upgraded components which will give better long term reliability and improved shifting
7. Scruffy looking black exhaust tips
Go to your local wheel repair shop and get them powder coated for less than $100
8. Mag ride delete modules
Cost from KW is $450
Make your own set of 4 for less than $80
Will post components soon
For a plug in mag ride delete solution
Buy 4 of these plug in tails
[/URL]
And 4 of these resistors
=[/URL]
OSMAN ,
U ROCK
Solder one resistor onto each set of tails.
The secure them using some tie-wraps to strap them onto the car
This pack will last you a lifetime for all sorts of uses
[/URL]
9. V8 Fuel Injectors - pre-facelift
Stealership $246.67 each
Buy from Hitachi ref FIJ0008 for around $90 each
10. Gen 1 Wiper Blades - LHD (not for UK, Australia, NZ etc)
Stealership $121.67
Buy from Bosch for around $50 - ref 3397014119
V10 Fuel Injectors (2009-2010)9. V8 Fuel Injectors - pre-facelift
Really useful post , much respect to you two.Wipers for Gen 1 just added on opening post
I may have just been unlucky, or my circumstances unique, but going down this route caused @Ricky.REP no end of problems and we ended up reverting to OEM injectors.9. V8 Fuel Injectors - pre-facelift
probably unlucky because there is no other ref for these injectorsI may have just been unlucky, or my circumstances unique, but going down this route caused @Ricky.REP no end of problems and we ended up reverting to OEM injectors.
As such, I would advise caution if considering using the Hitachi FIJ0008.
@TechNick What year is your car?I may have just been unlucky, or my circumstances unique, but going down this route caused @Ricky.REP no end of problems and we ended up reverting to OEM injectors.
As far as I can tell, the injector change has nothing to do with pre/post facelift, but rather the 8/23/10 date that roughly corresponds with 2011 Model Year vehicles.Having a 2012, it was extra interesting because I have a prefacelift but it calls for the post facelift injectors. The “D” version is what ended up buying.
Mine's a 2007 V8 (UK market)@TechNick What year is your car?
yes the AD version:As far as I can tell, the injector change has nothing to do with pre/post facelift, but rather the 8/23/10 date that roughly corresponds with 2011 Model Year vehicles.
I’m assuming you purchased the -AD version? The -D version is for 2008-2010 V8 engines.
If you see the parts note I posted above, Hitachi injectors were used only from 2007-2010 V8 and V10 engines, and then replaced by (I believe) Continental injectors. The base part number 079-906-036 remains the same for all variants, but the suffixes are different, and there are multiple supersessions.
- The 2009-2010 V10 Hitachi FIJ0038 (to 8/23/10) Audi Part Numbers are: 079-906-036-AA, 079-906-036-C
- The 2007-2010 V8 Hitachi FIJ0008 (to 8/23/10) Audi Part Numbers are: 079-906-036-AB, 079-906-036-D
- The 2011-2015 V8 & V10 Continental (from 8/23/10) versions are: 079-906-036-AD, 079-906-036-AC, 079-906-036-T, 079-906-036-N, 079-906-036-G (no known Continental OE cross-reference part number; apparently only sold through Audi)
