1 - 12 of 12 Posts
Had a mineshaft DA tonight so gave her a go on our closed track . Did everything to optimize , minimal fuel , high tire pressures and Auto Sport mode shifting . This car is a beast !
246374
That's awesome , definitely a record for N/A R8 .The best I've done was 6.79 . What's done to your car ?
What do V10 plus' typically run the 60-130 in?
Does a tuned non-plus end up with higher HP than a plus?
You will need to have both cars [stock V10 plus and regular V10 with tune ] run back to back on the same road . That's the only way to find out the difference
Discussion Starter #6
The RWS muddles things because it has less drivetrain loss being rwd, and mine is another 100 lbs lighter with my exhaust and wheel upgrade . So even making exactly plus power it should be faster from a roll . Will never hook up a launch like a plus though !
2018 Audi R8 V10 Plus - Vegas Yellow - ESMOTOR ES1000 Bolt On Twin Turbo Package
I have tested both stock, when my V10 Plus was stock, my best was 6.96 whilst my best in my pals R8 RWS was 8.23. Both 100% stock, factory Tyre pressures and UK pump fuel. Dragy below.
R8 RWS 2018
247540
R8 V10 Plus 2018
247541
1 - 12 of 12 Posts
