1 - 5 of 5 Posts
I've noticed my RNS-E restarts once in a while. Gets more and more often. Typically most pronounced right after cold start.
But it seems to be an entirely different system, as my speed activated central locking also reactivates. Nothing else seems to be affected.
Which system could result in this? Turning RNS off makes no difference for the central locking reaction
Discussion Starter · #3 ·
So, I have replace the RNS-E, based on the issue not happening while driving without that plugged in.
Still same issue.
Rear cam is and has not been working, only once in a blue moon had it enabled.
I have replaced the camera itself. No change. And now no change with the RNS-E replacement.
I'm guessing it must be a module somewhere, but what shares RNS as well as central locking?
There were some recent posts by someone else about the RNS-E and navigation. I would search it. Some of the responses the O.P. got mentioned updated firmware, etc. Maybe it will help your situation.
Scroll down, the O.P. was Gohan.
Reactions: Bovien
Discussion Starter · #5 ·
Found the issue. It's the ignition switch. That's apparently a relatively normal thing to wear down. Replaced in a very short time. All go.
Now, anyone wants the extra RNS-E I bought for no reason?
1 - 5 of 5 Posts
