Removal of bonnet and doors - wiring
2.5K views 6 replies 5 participants last post by  marytalk
#1 ·
Hi all,
To remove both the bonnet and doors appears simple enough however I'm finding it hard where exactly I'd be able to remove or unplug the wiring?
For the bonnet I've followed the wiring down from the bonnet hole and there isn't a connection? Same again for the doors however I think (I hope there's an easier way!) that I need to release all the connectors directly from the door and then pull all wiring through the door? Which I'm sure means removing the glass as there are connecters each side - a lot of added work :(
Any tips would be a great help! I'm currently turning my V10 Spyder Brown to Nardo Grey :)
#5 ·
I Removed my doors when I wrapped the car. Open the door and the loom has a connection. Remove the rubber housing between door and sill and just literally unplug the the loom from the door. No need to remove any door cards ect.
Not sure in bonnet as I didn't Remove this.
Hope this helps
Sent from my SM-G935F using Tapatalk
#6 ·
Does anyone know how to disconnect the windscreen jet washer pipes from the bonnet? Getting my bonnet repainted and PPS coated, bonnet looks easy to remove its just not obvious how to disconnect the washers.
