1 - 1 of 1 Posts
Suzuka Gray Audi R8 V10 with 20" GMG LMS Wheels and Lowering Springs
The Audi R8 has one of the most simple, elegant shapes in the world of supercars. Our client wanted a simple aesthetic upgrade while also improving the handling of the R8. We fitted the V10 beast with our LMS wheels and installed our sport lowering springs to give the car a menacing stance
GMG LMS Forged Monoblock Wheel
GMG forged monoblock wheels feature modern designs with scalloping built into the spokes for weight savings. Made in the USA from the highest quality US made 6061 T-6 aluminum forgings for exceptional strength, the GMG wheels are suitable for street and motorsports use with exceptional strength. Using Finite Element Analysis (FEA) computer simulation software, each application is tested to analyze the design under a simulated load to optimize strength and stiffness while minimizing mass. Each set of wheels will feature a custom finish with a standard color of your choice. Exquisite finishes such as brushed with color tinted clear coats or liquid paints are also available.
Features
- 6061-T6 Forged Aluminum
- Each application is tested using Finite Element Analysis (FEA) computer simulation software to optimize strength and minimize mass
- Back-pad lightening (pocketing) and scalloped spokes to reduce un-sprung mass & overall weight
- Suitable for road and track use
- Clear all BBK kits on the market
- Retain factory TPMS sensors
- Custom offsets available
- Available in a wide variety of colors and finishes
GMG Audi R8 Lowering Springs
The GMG R8 lowering springs improves the vehicle's performance, handling, and appearance.The kit features an increased spring rate and drops the vehicle by 20mm to lower the center of gravity of the vehicle to improve handling - reducing squat during acceleration, body roll in corners, and excessive nose-dive under braking - and to reduce fender gap to give the vehicle a lower, more aggressive stance.
The GMG R8 lowering springs utilizes a proprietary progressive spring design to maintain excellent ride quality. The progressive rate design uses a softer initial spring rate for excellent ride quality and a stiffer final rate for high performance handling. The spring rate increases when the vehicle is under load during cornering, braking, or load carrying etc. Crafted from a high quality steel, the springs will not set or sag over time.
The GMG WC lowering spring kit is sold as a complete set and is designed to be used with the factory dampers. The spring rates are proprietary to GMG and they are specifically matched to the factory dampers so that the vehicle won't be over-sprung and under-dampened or vice versa. As a great alternative to much more expensive and much more complicated coilover systems, the GMG lowering spring kit is an excellent set up for enthusiasts who would like to lower their car and improve handling without compromising comfort.
Key Features
- Drops the vehicle by 20mm to lower the center of gravity
- Improves handling - reducing squat during acceleration, body roll in corners, and excessive nose-dive under braking
- Reduce fender gap to give the vehicle a lower, more aggressive stance
- Progressive spring design for excellent ride quality
- Smooth softer initial spring rate for excellent ride quality and stiffer final rate for high performance handling
- Made of the highest quality high-tensile steel tubing to ensure consistent spring rates and no sagging
International Shipping is Available and Wholesale Inquiries are Welcomed
Professional installation is available at our facilities in Orange County California or through our worldwide dealer network in Europe, North America, Latin America, Africa and Middle East, Asia and Pacific.
For all questions and inquiries, please email [email protected] or [email protected]
1 - 1 of 1 Posts
