Only one way to find out
I just talked to @TriniTT and we’re pretty certain there is a difference. The diameter appears to be the same as an R8 but the Balboni version weighs 4 pounds more, so presumably it has a thicker wall.I’ve heard the front sway bar doesn’t need to be replaced, it’s already the same as the balboni gallardo.
Do you have the part munber for the stubs?I have the balboni rear sway bar and stubs but haven’t gotten around to replacing it.
Do you have those specs?in addition, I changed the toe and camber settings to match the Balboni Gallardo alignment specs.
If you do a detailed comparison I’d be interested in seeing if there is a difference but I think even the part number of the bars were exactly the same.I just talked to @TriniTT and we’re pretty certain there is a difference. The diameter appears to be the same as an R8 but the Balboni version weighs 4 pounds more, so presumably it has a thicker wall.
I updated the original post with these details.here are my current RWD alignment specs
I don't think there would be much of a performace improvement, but it would definitely be a good, aggressive look. It would theoretically shift the weight forward a bit, without creating a bigger gap between the tire and fender. But the increased wheel weight and the higher effective gear ratio from the larger tire diameter would likely be negatives. But I don't think this conversion is all about absolute performance anyway - it's about what makes the car more fun to drive, and the staggered wheels would add a nice aggressive look.Another thing I’ve been wondering about is if you go RWD would there be a benefit to a staggered wheel setup with maybe an inch difference from from front to rear wheel.
On my Evo RWD I’m planning to do 20/21 inch wheels and I’m wondering if maybe I should do 19/20 on the R8.
Aerodynamic down force is unchanged so long as the front suspension is lowered back down a few mm. But it shouldn’t be that different regardless.Is downforce at the front impacted significantly from taking all those pounds off? Rake angle needs adjustment?
86lbs is what is removed, but the front axle stubs you put in add back 3lbs total.The weight is slightly off from what you posted as to what actually came off of mine. I was a smidge over 86 pounds in full.
2.2lbsI just talked to @TriniTT and we’re pretty certain there is a difference. The diameter appears to be the same as an R8 but the Balboni version weighs 4 pounds more, so presumably it has a thicker wall.
Thanks for the info Tom! I’ll add this to the original post.
