Audi r8 2017 base
After installing oem plus wing with all plus components, took the fuse out, coded out 17&46 on vcds
traction control kicks in on 168km/h
And abs fault can’t be removed
printing the fault -
1 Fault Found:
0668 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_HSP_01_Timeout]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 57591 km
Date: 2023.03.15
Time: 16:43:32
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 99
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 57591 km
Date: 2023.03.15
Time: 16:43:32
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 99
