1 - 20 of 29 Posts
· Registered
its more likely that they are this:
There are no modifications; however, you do have to remove the airbag, trim and buttons, to then remove the OEM shifters - they are a direct swap with the factory paddles. Once you do that its reverse order to put everything back together!
So, less than 200 bucks and a couple of hours of your time.
· Registered
Discussion Starter · #7 ·
Are they still available ??
· Registered
Oh I didn’t even notice it was an actual shop. Thought it was an ad I saw before someone posted. Have you heard any reviews on them ??
I bought them - they are good quality and I will go through the effort of putting them on. It's a WAY better solution that 700 bucks for carbon or a stick on set. They look OEM. Surprised they are as cheap as they are.
· Matts Performance
R8+ 2016, S63 AMG Coupe, Panamera Turbo S e-H
That Urus style looks in R8 interior like disaster- way worse than OEM. I completely do not understand that someone want to go that way. Sorry guys just my thought no offence intended.
· Vendor
There are modifications required if you want to use the actual OEM Lamborghini paddles.
Copies have been made of these - and made to swap over the Audi internals
· Registered
Right, so, $500 bucks cheaper than OEM and made to swap right over with no modifications required.
I have a set and other than the fact that I have $500 bucks more in my wallet, I'm not sure what Lamborghini could do to make them better - they are very nice quality. They are more functional than the OEM R8 paddles (more to grab) and they don't flex like stick on versions. Sounds like a couple of people don't like them but for me, I'm not a fan of the oversized carbon options and these fit my tastes better.
· Premium Member
I agree...not sure what's not to like? I don't care for carbon fiber ones and I think these look OEM and slick compared to the actual OEM ones. I'm a fan!
Reactions: skilly
· Premium Member
The only confusing part is which part is it?
It says Style A is for 2015-2020 R8. Which obviously doesnt make sense as 2015 is still the gen1 R8. and Why is 2021+ different when 2020 and 2021 R8s are identical?
That doesn't make me confident to buy...
· Registered
It has to do with the inner set up of the paddle itself. If you email them they will guide you through the right version to order (they did for me). I should be putting mine on over the next couple of weeks and can report back too. If they work (they should) I can send you the information on what I ordered; my order was per their instructions.
· Premium Member
No I understand that part, what I'm saying is confusing is their description for what model year it fits. There is no way a 2015 R8 (Gen1) and a 2018 R8 (Gen2) would be the same paddles. And I can say with 100% certainty that there is no way 2020 R8 have different paddles from 2021 R8s. THAT is where my confusion lies..
1 - 20 of 29 Posts
