I’m looking to replace my daily driver RS5 (‘15) with an R8 (preferably a ‘14-‘15, but a ‘12 isn’t out of the question). I’ve been researching the R8 for a while and have a good grasp of its inherent issues. No need to reopen the mag ride, ac compressor, oil leak, coolant tank, and r-tronic discussions.
What I do need are some specifics and opinions. Mostly related to cold weather/snow driving. Yes, intentionally driving an R8 in the snow.
(I live in VT, and my business is in Killington).
Anyone with cold weather/winter/snow driving experience please chime in. I know some of you have had seat time in the snow.
I’ve been unable to find the factory ground clearance for the gen 1 R8 . I’ve seen it listed at 109mm to 160mm from various online sources. Can anyone give me the factory ground clearance on :
‘11-”12 V8 & V10 R8’s
‘14-’15 v8 & v10 R8’s
Are the v8 and v10 the same, or is the v10 lower?
My RS5 has ample clearance for my use. I’m just trying to see how much less clearance the R8 actually has, or if it’s actually lower.
Any gripes with the front/rear ratio split in snow? Does the rear kick out before the front catches up? My current car has 40/60 and it’s seamless.
Has anyone found an 18” (affordable) wheel set that clears the iron brakes? There are much better snow tire options at 18”, and the extra rubber might better for frequent pot holes.
How deep has the snow been before you feel yourself becoming a plow?
Any issues with snow/ice buildup inside the side blades. I assume the v10 might accumulate more since the openings are larger. I realize there might be some ice buildup in the wheel wells, but how about buildup in the front bumper vents?
Any issues with ice buildup on the engine hatch? This car will not always be parked indoors. We frequently get 3”-8” of snow while I’m parked in the lot. Warm glass + snow = ice
Any other issues arising from slogging it out with winter? Things I should be aware of? I know salt is a killer, and corrosion runs rampant around here. I undercoat my truck every year.
Are there specific areas on the R8 susceptible to rust?
Full disclosure. I also drive an F250, so for those really horrendous blizzards with knee high snow on the roads the R8 will stay at home.
Still, sometimes this happens while I’m at work.
