Front splitter- esthetically worth it or problem waiting to happen..?
10K views 22 replies 15 participants last post by  Marc1-V10
#1 ·
Good afternoon
curious to hear fellow r8 owners experience with front splitters . I think it looks quite nice but obviously worried about issues bottoming out, cracking it, & having to constantly be anxious/ worried about driveways or certain parts of roads etc.
Gen1 2012 model- Not a track car. Around town Weekend driver in Florida. (Most roads are flat but the occasional driveway / railway crossing etc).
Car has stock mag ride suspension
thx!
#6 ·
I have a Maxton splitter on mine as well. I've given it a few knocks and scrapes and its stood up to it well.
I think Ultimate PD on here sells them in the US.
258310
Reactions: SRM Autosports
#9 ·
I hear ya.
$2k carbon fiber splitter may be a waste but the Maxon could be something to consider as it’s inexpensive and still looks nice (is it carbon fiber vinyl print wrapped plastic...?).
and if it breaks at $350- so what. Dump it and lesson learned - or just buy another :)
#14 ·
IMO the Maxton is aesthetically the best, suits the car really well and gives it a lower look at the front that the car really needs. However, its not that easy to fix securely (I always worry if its going to come away at three figure speeds) and I don't think its as aerodynamic as a front splitter needs to be - more of a windbreak.
#16 ·
It's really down to your use case and tolerance for replacing things. I'm on my 3rd Maxton splitter. I drive the car hard, rally, etc. on mountain roads and am lowered on coilovers.
I've taken chunks out of the first two, third one is intact, but slightly warped (pretty sure nobody really notices except me). If you drive the car on nice roads, I can't imagine you'll have any issues. I know exactly what damaged each of the three I've had, and none of them were "typical" (first was small rocks thrown on a four day rally - replaced my full front end clear bra after for context, second was a rock big enough to clip the bottom of the lip on a mountain road that I saw too late, third dragged on an unexpected asymmetric bump at near/greater than triple digits).
I can personally attest that a professionally installed one will handle well into triple digit speeds without issue, and will take more abuse than should reasonably be expected for a ~$500 piece of plastic. I think of it as aesthetically pleasing bumper protection personally. The way the maxton lip is designed, scrapes won't be visible, so unless you're a jackass like me, it should last a long time.
I'm tempted to replace my skirts and lip with carbon ones from Eurobotique for purely cosmetic preference reasons (lip is nearly identical, but carbon, skirts are GT style), but those are more than twice the money, and that starts to be less pleasant to replace.
owns 2010 Audi R8 V10 Manual
#17 ·
my car came with the gt carbon fiber front splitter (gloss clear coat), u have to be careful still but it's been 5 years i havent scrapped at all. When I first got the car i didnt know how to properly drive or have skid plates and yes i scrapped a few times and learned my lesson. Switched out to a new one clear bra'ed it and never scrap again (skid plates definitely help in the edges and corners of the bumper, and lifts the car higher when it scrapes so the front splitter is safe)
#19 ·
I'm using Maxton.
Taped it on first install where you see here in red and used the supplied self tappers.
Tore it off at speed, which made a noise I thought I blew the car up.
Thankfully, it was still somewhat salvageable. So used Dremel to clean it up and reinstall with a dozen extra fasteners.
Use extremely good 2 sided tape.
Prep the crap out of surfaces and double or triple the hardware number provided, and you will be fine.
If it kerplodes now, I'll have much larger problems.
Sent from my SM-S911W using Tapatalk
#20 ·
Thanks! I have a Maxton ready to install. Do you recall what fasteners you used?
I'm using Maxton.
If it kerplodes now, I'll have much larger problems. View attachment 285609 View attachment 285610
#23 ·
Do it the right way & bolt it down. Self tapper WILL loosen over time whenever you scrape.
Learned my lesson when I used self tapper on my 997 lip. My Maxton lip comes with nut & bolts.
It's not that difficult to remove the bumper. Just take your time.
