Interesting thread. You guys are a bit harsh on the OP. I too haven’t gelled with the shift action, and I think it has something to do with the linkages. I’ve owned a B7 RS4 (completely different shift action) and unfortunately an S2000 as well (unfortunate becuase the shift action is so great it ruins all others
). I just don’t have a positive shift action and it sometimes pops out of third.
Anyways. Saw Renshaws mod he did to remove the play from the levers and bought the parts and had Audi install them today. Sadly that’s not the issue, another metal part is causing the play. So my cheap fix has now become a really expensive fix. I need to order the expensive parts and hopefully that solves it.
So, OP, check if it’s not the connectors etc that’s causing the issue because I do concur with most others here, the gated manual is the best to have.
The attached pic is the metal part which has a bit of play. It seems like a bushing PF some sort must be in there. It’s either worn or gone. Audi says I need to order the whole part since they don’t just supply the bushing. I’m going to start a separate thread to see if there are any better ideas out there. I don’t feel like spending the cash right now.
