I have a 2017 R8 with less than 10k on it and recently heard a slight, repetitive thump from one of the tires. Inspection confirmed the driver's side rear tire had a significant gash in it all the way down to the underlying steal belts, (see photo).
Looks to be purely cosmetic.
I'm kidding. So, I'm not a fan of the Pirelli's and have the following questions. Any feed back would be appreciated:
1. All of the tires have some tread left on them. The assumption is I cannot or should not replace the single defective tire.
2. If I want to abandon the Pirelli's then the assumption is I should replace all of the tires at this point as opposed to replacing the two rear P1's. In other words I shouldn't mix tires from different manufacturers, (e.g. Michelins on the rear and then eventually replacing the front tires to match - correct?)
3. Are the Michelin PS4S's the tire of choice these days?
4. Anyone in the Raleigh/Durham area, (North Carolina, USA), that can recommend a place to get these tires replaced?
Thank in advance for any advice!
NCPM,
You have a a lot of info coming at you - I won't try to address it all, but hopefully help with your original question. So you know the background of the person giving you a response - Our tires were one of my responsibilities as one of the four chassis design and release engineers on the '05-'06 Ford GT. I also did ride handling development on the FGT. I am sorry to see your badly damaged tire. Good time for the PS4S's.
1-2-3. Definitely replace tires in pairs (exact same tires). If there is not a lot of tire life left and big difference in age (more than 1 year) then it is time to head straight to the PS4S's. I agree completely with Dave L and others on these tires I will discuss below compared to two other tires.
The cracking - Pirellis are bit known for this with age. Too much toe will cause tire tread block feathering (and cupping if too much toe change...typically in braking). I don't see that here. We could talk about your usage, tire age, alignment and so on, but what I know is you didn't abuse the tire, especially if your alignment is within OEM spec (unless you were way under-inflated, which I also don't see signs of in tire wear). We could debate if the toe is too high, which I will be going through on mine in the next few weeks, but I promise the tire was developed for and run with those specs at Audi - low speed, high speed, serious handling, 24 hour durability, etc. Even if you were out a little the tire should not have this cracking. You may add some heat and uneven wear, but not overload or damage the tire like this shows. You can only truly overload these tires by going well above the top speed (aero load) or having an event in which tire damage is the least of your concerns.
I am going to write the following up in a detailed report and post when complete, but I have had a chance to compare the OEM PZeros (OEM sizes on 19's) on a 2011 R8 V10, the Hankook Ventus V12's at OEM sizes on my 2012 R8 V10. The short story is the PS4S's are 1-2 points better overall than the Pzero's for me and 3+ points better than the Hankook Ventus V12's.
So for me so far:
Steering - the PS4S are 1-2 point better than the PZeros for center feel, steering torque level and consistency, linearity/direct, feedback and wheel fight (steering wheel kicking back and forth with bumps in a straight line). The V12's are awful for steering and these attributes.
Ride - The PS4S's are 1-2 points better than the Pzero's for primary ride (big rounded bumps) and short choppy bumps and impacts. The impacts especially feel less harsh and more "rounded" (Damped) ont he PS4's. The V12's always just felt like I was bouncing on the tire.
Handling - at about 90% the grip level the PS4s' were only a little better for me than the Pzero's, but the communication of the limit, the predictability and feedback for me was 1-2 points better than the Pzero's. And drastically better than the V12's.
And I just had happen what others have noted...the V12's "went off" like we have in racing. Badly. I got about 500 miles of spirited driving in which they had decent grip, but were very vague, no feedback and not linear to suddenly no grip. I was aggressive on throttle in a straight line even and the V12's initially had decent grip with no traction control events. Then at 500 miles the traction control went crazy constantly. No grip. Done.
Hope this helps...I have this set of Hankook V12's with a lot of tread for sale! lol
